Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 10-11-2012, 14:40   #1 (permalink)
..::Mr.Asraf::..CTG™'s Avatar
Member: 1626159
Thanks Meter: 104
Nokia Lumia 920 hard reset
:::Before you buy a new cell phone or new tablet, please try the following procedure to repair your device. First charge your battery, backup your important data if possible and in most cases take out SIM and SD card. It is impossible to recover your data after doing a hard reset, so online backup is always important. You can also backup your data on your hard drive or a raid system.::::
First try this to soft reset your Nokia 920 Lumia. Press and hold the Volume down and Power buttons until it vibrates, after that you have to release all the keys then phone will vibrate 3 times.
To hard reset your Nokia Lumia 920 using key combination
Turn off your Nokia Lumia 920. Press and hold the following buttons Camera + Volume down + Power until your phone vibrates, then release only the Power key and keep pressing the Camera + Volume down for a couple of seconds 4-5s.
or
  1. On the Start screen, tap .
  2. Tap Settings > about phone.
  3. Tap reset your phone, and then tap yes.
The Following 2 Users Say Thank You to ..::Mr.Asraf::..CTG™ For This Useful Post:
Old 12-11-2012, 22:29   #2 (permalink)
mint centre's Avatar
Member: 195993
Sonork: 100.1653595
Thanks Meter: 128
got LUMIA 920 with security code and both combinations
soft/hard reset key solutions not working???
any other solution to remove password?
regards
MINT CENTRE...
Old 12-12-2012, 12:49   #3 (permalink)
Member: 195993
Sonork: 100.1653595
Thanks Meter: 128
[QUOTE=mint centre;9009109]Nokia Lumia 920 hard reset
this is the correct solution to remove password on LUMIA 920
Nokia Lumia with Windows Phone 8
Step 1
Make sure the charger is disconnected.
1. Switch the power Off.
2. Press and hold the Volume down and connect the charger, if succeed an exclamation mark (!) is shown on the screen.
(To cancel OS reset and exit to the normal mode, press the Volume Down + Power Key and hold them for 10 seconds).
Step 2
Then input Keys in the following order:
1. Volume up
2. Volume down
3. Power
4. Volume down
Step 3
The phone will reset and boot up automatically
regards
MINT CENTRE...
The Following 5 Users Say Thank You to mint centre For This Useful Post:
Old 04-21-2013, 08:00   #4 (permalink)
Member: 1395476
Sonork: Men7896
Thanks Meter: 52
[QUOTE=mint centre;9010819]
Step 1
Step 2
1. Volume up
2. Volume down
3. Power
4. Volume down
Step 3
regards
MINT CENTRE...
Hihi,
I tried the solution.
it show the 2 wheel rolling after reset.
how long it take to restart?
its been already 2 hrs waiting since reset still same wheel rolling..
any solution?
Thanks in advance.
Regards
Old 05-07-2013, 11:11   #5 (permalink)
Member: 1898067
Sonork: 100.1627754
i have a lumia 920 that is working but screen is black hard nor soft reset works if you have the solution please
Old 05-10-2013, 20:56   #6 (permalink)
zipikiki's Avatar
Member: 85182
Sonork: 1593854
Thanks Meter: 42
How delete time conversation on Lumia 920. I have Advance box and Best Dongle.
Best Reguards
Old 06-05-2013, 16:58   #7 (permalink)
Member: 1450499
Thanks Meter: 3
Nokia Lumia 920 Hard reset stuck solution.
Hi Guys i am very glade to share this with you if all things not working what is in above posts apply this method, while you see two gears on the screen, and you thing it won't go for long time ,
open the two screws and pull the battery out from the phone
put it back and its done,
works 100000000000000000000000000%
i did mine and its perfect
don't forget to say thanks
Old 06-10-2013, 07:54   #8 (permalink)
Member: 1952786
Thanks Meter: 2
Sometimes this problem occur due to the screen protector. Just remove it and then check
Old 07-31-2013, 15:03   #9 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
lumia 920 after hardrest only logo
i need urgenly solution
thx
Old 08-26-2013, 19:28   #10 (permalink)
Member: 366741
Thanks Meter: 3
Please tell me how to connect Lumia 920 with PC
Old 10-08-2013, 09:59   #11 (permalink)
APZ
Registered User
Member: 382531
Thanks Meter: 2
For atou
Try mint centre solution just worked for me.
Thanks to mint centre
Old 12-24-2013, 14:23   #12 (permalink)
Member: 1844680
Sonork: hadiq
Thanks Meter: 3
hi i tried it but when it shows exclamation sign after i press volume up the phone comes on not going to be hard reseted plz help thanks
Old 03-05-2014, 13:41   #13 (permalink)
Member: 1999375
Sonork: sarfaraz
lumia 920 black screen
Old 12-11-2014, 10:11   #14 (permalink)
Member: 2284783
Sonork: 100.1661528
Thanks Meter: 4
nokia lumia 620 hard reset
sir any soulotion
hard reset in just few minuites
Old 06-06-2015, 09:50   #15 (permalink)
Member: 2379571
nokia lumia 625
when it open it show some stain
any solution? plz help me................
Page generated in 0.24038 seconds with 8 queries
