Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here |
09-10-2012, 09:04 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: Insite IC
Member: 1757379 Status: Offline Sonork: no need Thanks Meter: 400 | Interop-Unlock Lumia 800 plus bootloader and NAND access [Q&A] Questions & Answers Q: I've a Lumia 800 or 710 can I Interop-Unlock it? A: The short answer is yes if you have a Lumia 710 - you must firstly downgrade your bootloader - and "maybe" for the Lumia 800, because only some of them can be Interop-Unlocked at the moment. Q: I've got a Lumia 710 how can I downgrade my bootloader to the Qualcomm one? A: Youmust flash Яндекс.Народ with Nokia Care Suite (mirror splitted in two parts RM-803.part1.rar RM-803.part1.rar Q: Cool how can I discover if I'm a lucky owner or not? A: For first go to "Settings -> About -> more info" and if your "Hardware revision number" ends with 2.4 you are probably screwed out. Q: I've got 2.4 hw rev how can I check eventually? A: You don't need to check if your hw rev is 2.4 and your Lumia came with firmware 11500 or higher you have the new nokia bootloader. Q: I've got 2.3 hw rev how can I check if I'm eligible? A: If you've got hw rev 2.3 but you have flashed your device with a firmware 11500 or higher - flashed mean with Nokia Care Suite because Zune doesn't update your bootloader - you have the new Nokia Bootloader; if you want eventually to check see below "check if my device is interop-unlockable". Q: So at the moment which can be interop-unlocked? A: As for now can be interop-unlocked hw rev 2.3 with firmware version 11141 or below. Q: I've got the NOKIA DLOAD can I put the Qualcomm bootloader? Yes but ONLY if you have a Lumia 710, on the 800 is not possible at the moment. Q: Can I get the Qualcomm bootloader by downgrading my Lumia ? No, you can't flash the Qualcomm bootloader with a backup, as Q: I have interop-unlocked my Lumia but now I can't access Windows Live services! : You can find your solution xda-developers - View Single Post - DEV ONLY - NAND access + Full Unlock for Lumia 710 & 800 Q: I've got the NOKIA DLOAD how can I flash my device? A: You can ONLY flash your device with Nokia Care Suite. Q: I've got the Qualcomm bootloader how can I flash my device? A: You can ONLY flash your device with Qualcomm .QPST The Story so far: Nokia Interop-Unlock plus bootloader and NAND access Check if my device is Interop-Unlockable Shut down your device Hold pushed VOL + and POWER Plug into your USB, you will hear a short vibration If you are running Windows it will ask to format an USB drive, say no! then you can Interop-Unlock your Lumia with one of the following ROM: Lumia 800: Interop Unlock (no full unlock yet) ROM based on: RM819_059P453_1600.2487.8107.12070_002 Mediafire folder access: Lumia 710 interopunlock without apps - test4.part1.rar Free Cloud Storage - MediaFire os-new.part2.rar os-new.part3.rar os-new.part4.rar Lumia 710: Interop Unlock (no full unlock yet) ROM Based on: RM803_059N2L6_1600.3015.8107.12070_010 Mediafire folder access: Free Cloud Storage - MediaFire CAUTION: these images AREN'T TESTED. Use at your own risk. After that, you'll need to hard reset the phone: Hold Power button for 10 seconds to exit Qualcomm's disk mode, and press and hold POWER+VOLUMEDOWN+CAMERA until you feel the phone vibrate. After that, RELEASE power button but KEEP HOLDING volume down + camera for five or more seconds This will trigger the hard reset. If when you plug your device and you see NOKIA DLOAD for now your out of luck because your bootloader is locked and you can't flash the roms above. Lumia 710 & 800 ROMs Full Unlocked ROM for Nokia Lumia 710 XDA Files - Lumia800/ROM/Zipped Qualcomm Disk layout [B]Completed the file uploads: Free Cloud Storage - MediaFire Dump_in_parts.part*.rar : Dump of the OS partition (IMGFS dump) Dumpmap-imgfsobjects.zip: logs and stuff from OSBuilder sd*.rar: compressed DD dumps of the rest of the filesystem NOT INCLUDED: Partition #5: contains product code and stuff from phone, 64kb Partition #4: Extended partition container for partitions 5-9 Partition #9: Cannot post that enormous partition, 15Gb in size (but should be enough with the dumped os). [COLOR="*****Brown"]LUMIA 800 FLASH FILE SYSTEM LAYOUT:[/COLOR] Partition Begin End Blocks ID /dev/sdb1 * 1 1000 500 4d Initial Bootloader - SECBOOT /dev/sdb2 1001 4000 1500 46 Second stage loader? - OSBL, also looks like it has the download mode and seems to init LCD, enable USB etc. /dev/sdb3 4001 304000 150000 c W95 FAT32 (LBA) - Writable partition with EMMCBOOT, AMSS etc. EMMCBoot is responsible for loading Windows Kernel (nk.exe). I got a copy of Samsung Galaxy i9001's emmcboot.mbn, and putted it in there. It tries to start, but seems to crash (expected). But hey! it tries to boot it (it even vibrates for 1/10 of a second), so getting something else (did anyone say...android?)running on this phone should be easier than in lots of other phones... Does anyone have u-boot ports for Qualcomm 8255? /dev/sdb4 304001 31037579 15366789+ 5 Extended partition which holds the OS /dev/sdb5 304006 304133 64 ef EFI (FAT-12/16/32) - Linux detects it as an EFI partition, but it's just 64Kb size, and seems to have some markers, not sure yet what it is, but could be anything from IMEI and simlock to an actual efi partiton for WinCE... EDIT AGAIN: this partition contains phone serial number and product code, and possibly imei and simlock. For sure its not an efi partition /dev/sdb6 304134 310277 3072 58 3Mb size /dev/sdb7 393216 399359 3072 4a 3Mb size /dev/sdb8 399360 405503 3072 4b 3Mb size These three partitions have similar start and end data on their partitions, no idea what they are, since I haven't been able to see if it's even a file system. All the documentation I see seems to tell Windows Mobile uses exFAT for the filesystem, but can't seem to find its header anywhere on the flash... still looking. It could even be where WinMo stores application installers for first boot on the device (but could be perfectly wrong) All of them start with the following header (hex): 7D 8D 27 82 D7 40 F8 90 53 22 82 43 6D EC 6F 69 49 /dev/sdb9 524288 31156362 15316037+ 48 This las partition is 15Gb size, and contains all the Operating System and all the data on the phone. Anyone know about how does Windows Phone manage filesystems on NAND? Some help would be really appreciated... The file system for the 15Gb partition has _wmstore header, still incompatible with some kitchens, but still looking... Here's part of the header: Code: _wmstore !zLH?k _wmpart_B _wmpart_S _wmpart_S _wmpart_N _wmpart_U _wmpart_D _wmpart_I _wmpart_P _wmpart_U PSBdX GFCB SRPX LK Bootloader for Lumia https://github.com/beidl/lk_umia *** Compiling the LK Android bootloader *** ** Tested on Ubuntu 11.10 with Lumia 710 ** 1) Get the toolchain and install: wget https://sourcery.mentor.com/public/g...ux-gnu.tar.bz2 sudo tar xvf arm-2009q1-203-arm-none-linux-gnueabi-i686-pc-linux-gnu.tar.bz2 --directory /opt/ 2) Compile the bootloader: PATH=/opt/arm-2009q1/bin:$PATH TOOLCHAIN_PREFIX=arm-none-linux-gnueabi- PROJECT=msm7630_surf make EMMC_BOOT=1 3) Get your Lumia into diagnostics mode (turn it on using VOL UP + VOL DOWN + POWER) 4) BACKUP EVERY SINGLE FILE FROM THE 150MB PARTITION! (Just to be safe) 5) Replace the image/emmcboot.mbn file with your freshly compiled LK bootloader cp <repo dir>/build-msm7630_surf/EMMCBOOT.MBN /media/<mount point>/image2/emmcboot.mbn 6) Unmount the bootloader partition from your PC and pull the phone's battery 7) Turn on, wait a few moments, and plug the phone to the PC 8) Test the fastboot connection: fastboot devices fastboot getvar version for now is working only the fastboot protocol but nothing more, is in current alpha stage. br: ub |
