Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 08-21-2010, 10:34   #1 (permalink)
FaHaD_DePaR's Avatar
Member: 1257171
Thanks Meter: 86
Arrow NOKIA N900 Flashing Successfull
1 N900
[edit]
Updating the firmware using the Nokia Software Updater
Microsoft Windows users who wish to update their N900 can use the Nokia Software Updater (aka NSU), or use the Flasher (see section below).
The Nokia Software Updater is compatible with Windows XP Service Pack 3, Windows Vista Service Pack 2, and Windows 7. (Some users may encounter problems due to varying causes.)
The Nokia Software Updater can only be used when updating from a previous firmware to a new one. To reflash with the same firmware you currently have, or if you missed an update, use the flasher.
[edit] Updating or re-flashing the firmware using the Flasher
Note: This method is fully compatible with 32 bit versions of Windows; 64-bit users may encounter problems.
To flash from the Windows (XP, Vista, or 7) command line,
  1. Download and install the latest version of the Flasher.
  2. Download the latest firmware (.bin) file for your region and save it to %ProgramFiles%\maemo\flasher-3.5\, or wherever you installed the Flasher.
  3. Ensure the battery is at least half full.
  4. Unplug USB cable if present, and switch off the device.
  5. Run the Flasher from the Start menu
  6. This is an alternate to step 5, if you have already opened the Flasher, ignore this step. Open the Command Prompt (Start then Run or Windows Logo key + R) and type cmd then press Enter. Change the directory to where you installed the Flasher (TIP: Use the TAB key to auto-complete commands and file-names)cd "%ProgramFiles%\maemo\flasher-3.5"
  7. Hold the u key on the device keyboard and connect the USB cable at the same time. See the Flasher documentation for more information. (TIP: Hold the u key until Windows has successfully installed the driver.)
  8. Run the following command:flasher-3.5.exe -F RX-51_2009SE_2.2009.51-1_PR_COMBINED_MR0_ARM.bin -f -R
Replace RX-51_2009SE_2.2009.51-1_PR_COMBINED_MR0_ARM.bin with the firmware you wish to update. The latest PR1.2 official (rootfs) images are listed below:
USA
RX-51_2009SE_10.2010.19-1.002_PR_COMBINED_002_ARM.binMiddle East and North Africa
RX-51_2009SE_10.2010.19-1.003_PR_COMBINED_003_ARM.binIndia
RX-51_2009SE_10.2010.19-1.004_PR_COMBINED_004_ARM.binUK
(not the vodafone firmware, but fully compatible with vodafone devices).
RX-51_2009SE_10.2010.19-1.203.1_PR_COMBINED_203_ARM.binGlobal
RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin
The flash will take approximately 2-5 minutes after which the N900 will reboot and display the Welcome Screen with Regional settings. After booting, you may use the backup utility to restore your settings.
The Following User Says Thank You to FaHaD_DePaR For This Useful Post:
Old 01-19-2014, 10:51   #2 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 330
download link not working.............?
Old 01-19-2014, 11:39   #3 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 94
download link not working plz... repair it bro.....
Old 02-06-2014, 17:41   #4 (permalink)
omi17's Avatar
Member: 1950912
Sonork: 100.1654643(Offline)
Thanks Meter: 389
Smile New Link!!!
Here is new link for flasher !!
maemo_flasher-3.5_2.5.2.2 - Download - 4shared - ????? ?????
Old 02-11-2014, 18:57   #5 (permalink)
Member: 1290061
Thanks Meter: 59
firmware img not working
Old 02-14-2014, 07:47   #6 (permalink)
omi17's Avatar
Member: 1950912
Thanks Meter: 389
Smile New Link !!!
Here Is New Link For Ur Firmware !!
http://nds2.fds-fire.nokia.com/fdp/i...ED_003_ARM.bin
OR
http://nds2.fds-fire.nokia.com/fdp/i...0.36.2_001.dcp
http://nds2.fds-fire.nokia.com/fdp/i..._signature.bin
http://nds2.fds-fire.nokia.com/fdp/i...0.36.2_001.vpl
Here is all firmware package
Old 02-09-2017, 11:37   #7 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 214
Link Dead......................
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.29242 seconds with 8 queries
