Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 02-25-2014, 16:52   #16 (permalink)
*Diablo*'s Avatar
Member: 59173
Sonork: 100.1585568
Thanks Meter: 225
use direct unlock . nkwp8.info
Old 04-23-2014, 06:36   #17 (permalink)
mobista's Avatar
Member: 1031096
Thanks Meter: 77
Did somebody solve this problem? I'm trying with different SIM Card but not succes
Old 04-29-2014, 06:10   #18 (permalink)
Member: 1877687
Thanks Meter: 21
Flash with a generic firmware !
Old 07-25-2014, 22:19   #19 (permalink)
Member: 1820493
Thanks Meter: 3
Originally Posted by mgtsales View Post
code:67445440984985597700 lockedx to vodafone UK.
Me too the phone requires pin code(unlock code) 10 tries remaining, after entering good code says pin incorect 9 tries left. If i try entering again unlock code it says code error but when i restart the phone the counter remains at 10 tries remaining. the tries always come back to 10.
That's normal. Seen it on thousands of nokia 1020
Old 08-28-2014, 20:22   #20 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question
Originally Posted by digitalgsm_cora View Post
My unlock code has 16 digits ! The code came from SFR France. I've talk again with them and they said the unlock code is correct and should be in 16 digits.
B.R.
hello
did you solved the problem ? how ?
thanks
Old 08-30-2014, 19:11   #21 (permalink)
Member: 2249427
Originally Posted by mascodis View Post
nokia lumia 520 sfr puts me card error when I try to put the unlock code please help me
can you please help me to unlocka nokia lumia 520.2
Old 11-04-2014, 10:19   #22 (permalink)
Member: 821750
Sonork: 19790515
Thanks Meter: 29
we wait solution please.....
Old 11-22-2014, 08:17   #23 (permalink)
Member: 2297432
I also get an problem in my nokia lumia 520.i forgot my password how i reset it
Old 01-13-2015, 23:18   #24 (permalink)
Member: 1297547
Thanks Meter: 5
i have the same problem with lumia 520 Bouygues telecom france !!!!????
Old 02-23-2015, 17:49   #25 (permalink)
Member: 782600
Thanks Meter: 4
same problem with o2
Old 02-27-2015, 01:51   #26 (permalink)
Member: 2169629
Thanks Meter: 6
lumia 520 Movistar/Peru tested
whitout flash
the solution is best infinity dongle
1. connect in normal mode
2.-switch to test mode using the best sw
3.- wait to install drivers
4.-select the option to repair
5.-clear sim lock
6.-switch to normal mode using the best sw
7.-enter code and enjoy
Done by GT-SMART
The Following 2 Users Say Thank You to nino666 For This Useful Post:
Old 04-15-2015, 23:17   #27 (permalink)
Member: 2029583
someone solve this problem?. I have the same issue ...
Old 04-23-2015, 05:33   #28 (permalink)
Member: 2169629
Thanks Meter: 6
You need best dongle infinity
Old 04-30-2015, 13:30   #29 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
Phone found!
WP8x Nokia Phone detected
Read info... Ok
Clearing SimLock code data...
Something goes wrong :|
Old 07-10-2015, 04:59   #30 (permalink)
Member: 2255214
not work for me i try it but the same problem
Page generated in 0.23557 seconds with 8 queries
