Dashboard Servicing all digital dashboards |
07-29-2015, 08:34 | #17 (permalink) |
No Life Poster Join Date: Mar 2003 Location: GB Age: 54
Member: 24791 Status: Offline Thanks Meter: 35 | If you only need one car doing then probably better to pay someone to do it or use digiprog 3 if it don't go through obd then you need to remove cluster to do it |
08-01-2015, 06:02 | #19 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2435411 Status: Offline Thanks Meter: 0 | hi thanks for that. ive tried the latest version of the digiprog 3 & it cant do it through obd, ive had the cluster out & disassembled but no common knowledge as to what ic is the correct one. so still looking for a product/software that can do this job. ive had much speculation as to what product will do the job as i had with the digiprog but before i spend more money i need to know for sure that the item will actually do the job. so can anyone tell me for sure what product/software can do this job that wont break the bank? thanks again |
08-01-2015, 08:17 | #20 (permalink) | |
Member: 24791 Status: Offline Thanks Meter: 35 | Quote:
https://www.dropbox.com/s/xfyq6yevd3...ftLtd.pdf?dl=0 Or Hc9s12 https://www.dropbox.com/s/osgx2zkeys...ftLtd.pdf?dl=0 Alternative https://www.dropbox.com/s/j3wt1cu9bx...ftLtd.pdf?dl=0 OBD via ST16 https://www.dropbox.com/s/pkqviwzrz2...ftLtd.pdf?dl=0 | |
The Following User Says Thank You to teerak2uk For This Useful Post: |
08-03-2015, 11:07 | #21 (permalink) |
Member: 2435411 Status: Offline Thanks Meter: 0 | ok thanks for that. ive seen the first 3 options & they are not relevant to this models different circuit board, but am most interested in the last as i have not seen this. the only issue i see here is the 2010 mondeo comes with or without various options & the one i have here does not have remote starting, ie... can only be started by using the key. i still may have a go but starting with key although it probably wont work. what are your thoughts on the blue obd2 device on the last drop you gave me as my plug/cable 16 is not wifi as i suspect the blue one is... therefore how would you use this with the digiprog as im sure they are not wifi enabled? very interesting still & thanks for your trouble! |
08-03-2015, 11:56 | #22 (permalink) | |
08-03-2015, 13:47 | #23 (permalink) | |
Member: 2435411 Status: Offline Thanks Meter: 0 | Quote:
or not... i clicked attachments, then chose 3 pics, clicked upload, says "failed contact admin" tried again, same, tried one at a time, same. tried on my phone, same. sorry bit lost as what to do now? | |
02-29-2016, 02:22 | #27 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2538782 Status: Offline Thanks Meter: 0 | I am looking to program 2007 Escalade, 2008 silverado, and a 2004 BMW x5.... What is best and cheapest recommendations? I prefer to use the OBD 2, but I have some experience at clipping onto the chips. Any used equipment out there ? Thanks, Rob |
