Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Dashboard Servicing all digital dashboards |
| | #1 (permalink) |
| Junior Member ![]() ![]() Join Date: Mar 2004 Location: sheffield united kingdom Age: 41
Member: 58930 Status: Offline Thanks: 12
| Big problem with audi a3 crypto dash !! hi i have a real big problem and hope to gain some advice from here . i have an audi a3 2005 with crypto dash and 93lc86c eprom needed login and mileage correction on dash so was advised to dump eprom with vag k+ can . could not dump entire eprom to retrieve login amnd mileage . was then told to use a programmer so i removed eprom from clocks and read it with a willem programmer . in hex editor dump is all ff ff ff ff did not erase just attempted to read over and over for hours always same result ff ff ff ff inserted eprom back onto dash , dash is now dead and reads .DEL nothing works and car does not start and is immobilised bought new 93cl86c eprom to try to write part dump from vag k+can to eprom . willem says program succesful but when read this is also ff ff ff ff if i replace dash with used one . how can i get immobiliser to work and how can i program my key to this dash ? i have vcds original and maybe adapt clocks if i can get login but key will not work and mileage will also be wrong . some one please advise thank you |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Wrexham, Wales
Member: 469145 Status: Offline Thanks: 691
| Quote:
| | #3 (permalink) |
| when soldered back into clocks ,pins have been checked for continuity eprom is correct way in clocks , as for the rotated pins i have checked the data sheet for the eprom and the eprom doesnt seem to be rotated . the only problem i find is no one wants to share the information . im concerned with the willem not reading the eprom after it returns a succesful burn . |
| | #4 (permalink) | |
| Quote:
This is a nightmare for you.. | |
| | #5 (permalink) | |
| Quote:
Pass in PM | |
| | #6 (permalink) | |
| Quote:
0570: xx xx xx xx xx xx xx xx 00 01 E6 28 xx xx xx xx 05D0: xx xx xx xx xx xx xx xx 00 01 E6 28 xx xx xx xx | |
| | #7 (permalink) |
| many thanks for your help here shooting . i know what i will be doing tonight i have what i would say is a part dump from the clocks .done with vag dash i dont know if it is possible to find all the info needed to insert it into another dump from the same dash version . |
| The Following User Says Thank You to hollow For This Useful Post: |
| | #8 (permalink) | |
| Quote:
| | #9 (permalink) | |
| Quote:
The posted dump is way too small... | |
| | #10 (permalink) | |
| Quote:
Can you re-read it as 93c86 8bit and as 16bit.. and we can see the comparison.. | |
| | #12 (permalink) | |
| Quote:
it looks like you had the programmer set to bigger than 93c86 when reading.. Very odd.. I suggest looking for another dump from a similar clocks and compair.. | |
| | #13 (permalink) |
| the dump i posted wasent done with the willem it was done a few months ago with a can commander tool to try to retrieve the login code for the clocks . unsuccesfully ..... where bsides audi can i get the keys adapted to another set of clocks or with them been crypto do i need new transponders ? |
| | #14 (permalink) | |
| Quote:
| | #15 (permalink) |
| lol i like the sound of that do ppl still use the yellow pages hahaha well still cant get willem to program new eprom ??? head thrashing now , need a new programmer i think |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
| big big big big big problem with server | software zone | FuriouS TeaM Products | 1 | 01-16-2008 16:25 |
| big big big problem with lurker!!! | Bugytech | Wray´s Products | 9 | 11-23-2004 07:55 |
| BIG BIG BIG Problem with DCT-3 and UFS3 | PhonePlus | UFS2 + UFS3-Tornadoflasher | 7 | 09-03-2004 09:50 |
| BIG BIG BIG problem with SPC2 and VKLAY | wael_nasreddine | E-Gold Based Phones | 2 | 12-22-2003 21:23 |
