ECU & IMMO Diagnostic, Immobilizer, Chip Tuning |
02-17-2013, 08:04 | #1 (permalink) |
Junior Member Join Date: Oct 2006 Location: Novi Sad Age: 46
Member: 367739 Status: Offline Thanks Meter: 0 | Fiat Coupe 4Q4 Immo I need immo off or virgin state eeprom (or both) for learning. M.Marelli ECU: IAW 4Q4 P-8 software version 193.02 IMMO 68hc11e9 eeprom attached 10x |
02-21-2013, 14:37 | #3 (permalink) |
Member: 367739 Status: Offline Thanks Meter: 0 | I took a look in PDF, thanks, but I already knew that information! But I still need that M1 Motorola eeprom bin file! Thats my problem, or that from Lancia Q5 in this forum (file is here, but password protected) I know if I change 27c256 (have good eprom A1 file) engine will start OK but it is not possilbe to turn off Engine MIL in the Dashboard (Immo errors in ECU not possible to erase). So I would like to be able to turn MIL Lamp of with good eeprom and to see MIL only when have a real problem with engine management (sensor goes down etc. and not to be lit all the time because of immo) I was messing with 68hc eeprom and succeded to turn Lamp off, but after I reset ECU for a few times it comes back on. I need eeprom file for that ecu or for similar (delta 4q5). thanks in advance |
