Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc. |
12-27-2008, 12:53 | #16 (permalink) |
No Life Poster Join Date: Dec 2003 Age: 36
Member: 47281 Status: Offline Thanks Meter: 17 | 1.What is it??</b> It's an open source operating system which is now being used by many people and even computer scientists to expose the underlying of operating systems. The core of any OS is the kernel which is responsible for communicating with your hardware. You communicate with your OS and OS tells the kernel and kernel coorporates with the hardware. 2. Why linux?? Because it is completely free of charge and you can modify your source and build a generic version of linux for yourself. You can even hack the linux kernel by assigning prioritties to the job which your prefer. 3. Which linux is good for me?? Well there plenty versions of linux available on the net. i use kubuntu. ubuntu is prefixed with K which stands for KDE(k-Developer Environment), an interface which is more kind of cool compared to the ubuntu which uses Genome. Genome consumes less memory and there is no big performance penalty as compared to KDE. KDE is more flexible. In windows you used to click start>run and then type the command which suits your need, but on kubuntu you would press Alt+Space which launches katapult "aka known as run" and then type the app which you want to launch. 4. How do I install linux applications?? Each version of linux has its own package manager/installer. In kubuntu we have synaptic package manager and in ubuntu we have adept. You even use the command line to download and install an application. E.g of commands are: sudo apt-get install xxx sudo denotes a super user which can manage user accounts/kill processes and install/remove apps.. xxx is the application name.. apt-get is the code name for get application.. do I continue??? |
12-27-2008, 13:41 | #17 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Thanks for your info about Linux it was clear and very good and yes if anyone want Ubuntu Kubuntu Edubuntu Xbunutu it's free of charge you can request for a copy of any of these ubuntu for free at your home just request and get it within a week request now from here https://shipit.ubuntu.com/ |
12-27-2008, 15:24 | #18 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Services You Can Disable There are quite a few services you can disable from starting automatically. This would be to speed up your boot time and free resources. They are only suggestions so I suggestion you read the description of each one when you run Services and that you turn them off one at a time. Some possibilities are: Alerter Application Management Clipbook Fast UserSwitching Human Interface Devices Indexing Service Messenger Net Logon NetMeeting QOS RSVP Remote Desktop Help Session Manager Remote Registry Routing & Remote Access SSDP Discovery Service Universal Plug and Play Device Host Web Client -------------------------------------------------------------------------------- Cleaning the Prefetch Directory WindowsXP has a new feature called Prefetch. This keeps a shortcut to recently used programs. However it can fill up with old and obsolete programs. To clean this periodically go to: Star / Run / Prefetch Press Ctrl-A to highlight all the shorcuts Delete them -------------------------------------------------------------------------------- Not Displaying Logon, Logoff, Startup and Shutdown Status Messages To turn these off: Start Regedit Go to HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentV ersionpoliciessystem If it is not already there, create a DWORD value named DisableStatusMessages Give it a value of 1 -------------------------------------------------------------------------------- Clearing the Page File on Shutdown Click on the Start button Go to the Control Panel Administrative Tools Local Security Policy Local Policies Click on Security Options Right hand menu - right click on "Shutdown: Clear Virtual Memory Pagefile" Select "Enable" Reboot For regedit users..... If you want to clear the page file on each shutdown: Start Regedit Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSe ssion ManagerMemory ManagementClearPageFileAtShutdown Set the value to 1 -------------------------------------------------------------------------------- No GUI Boot If you don't need to see the XP boot logo, Run MSCONFIG Click on the BOOT.INI tab Check the box for /NOGUIBOOT --------------------------------------------------------------------------------- Speeding the Startup of Some CD Burner Programs If you use program other than the native WindowsXP CD Burner software, you might be able to increase the speed that it loads. Go to Control Panel / Administrative Tools / Services Double-click on IMAPI CD-Burning COM Service For the Startup Type, select Disabled Click on the OK button and then close the Services window If you dont You should notice -------------------------------------------------------------------------------- Getting Rid of Unread Email Messages To remove the Unread Email message by user's login names: Start Regedit For a single user: Go to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVe rsionUnreadMail For all users: Go to HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentV ersionUnreadMail Create a DWORD key called MessageExpiryDays Give it a value of 0 ------------------------------------------------------------------------------ Decreasing Boot Time Microsoft has made available a program to analyze and decrease the time it takes to boot to WindowsXP The program is called BootVis Uncompress the file. Run BOOTVIS.EXE For a starting point, run Trace / Next Boot + Driver Delays This will reboot your computer and provide a benchmark After the reboot, BootVis will take a minute or two to show graphs of your system startup. Note how much time it takes for your system to load (click on the red vertical line) Then run Trace / Optimize System Re-Run the Next Boot + Drive Delays Note how much the time has decreased Mine went from approximately 33 to 25 seconds. -------------------------------------------------------------------------------- Increasing Graphics Performance By default, WindowsXP turns on a lot of shadows, fades, slides etc to menu items. Most simply slow down their display. To turn these off selectively: Right click on the My Computer icon Select Properties Click on the Advanced tab Under Performance, click on the Settings button To turn them all of, select Adjust for best performance My preference is to leave them all off except for Show shadows under mouse pointer and Show window contents while dragging --------------------------------------------------------------------------- Increasing System Performance If you have 512 megs or more of memory, you can increase system performance by having the core system kept in memory. Start Regedit Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSe ssion ManagerMemory ManagementDisablePagingExecutive Set the value to be 1 Reboot the computer --------------------------------------------------------------------------- Increasing File System Caching To increase the amount of memory Windows will locked for I/O operations: Start Regedit Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSe ssion ManagerMemory Management Edit the key IoPageLockLimit ----------------------------------------------------------------------------- Resolving Inability to Add or Remove Programs If a particular user cannot add or remove programs, there might be a simple registry edit neeed. Go to HKCUSoftwareMicrosoftWindowsCurrentVersionPolicies Uninstall Change the DWORD NoAddRemovePrograms to 0 disable it 4096 - 32megs of memory or less 8192 - 32+ megs of memory 16384 - 64+ megs of memory 32768 - 128+ megs of memory 65536 - 256+ megs of memory |
12-27-2008, 15:27 | #19 (permalink) | ||||
No Life Poster Join Date: Oct 2007
Member: 604795 Status: Offline Thanks Meter: 822 | Quote:
this is a very old bug which is removed in later versions (I Guess) why only CON? you can also not create Folder with the name 'LPT1' to 'LPT9', 'COM1' to 'COM9', 'NUL', etc... here is the solution to create the folder named con and other system variables. Quote:
you can also create a folder named con with ASCII characters. Quote:
for more information you can also read Microsoft's Article related to this issue: http://support.microsoft.com/kb/315226/ what will you do for me if i complete your challenge? | ||||
The Following 2 Users Say Thank You to ..::Ahsan::.. For This Useful Post: |
12-27-2008, 15:33 | #22 (permalink) | |
btw: as i already told this bug is removed in later versions of windows so it's easily possible. but there are many tricks like using C++,CMD, or ASCII to create such type of folders also in older versions of windows. did you checked the trick i posted? which version of windows you are using, which build? | |
12-27-2008, 15:38 | #23 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Yes you have beat me i made a folder in my XP SP3 with the commands you gave that was great therefore request you to post your new news about windows i'm very happy to meet you here in GSMHOSTING keep posting about windows or linux whatever you have thanks again |
12-27-2008, 19:27 | #24 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Inside Darkness Age: 39
Member: 101449 Status: Offline Sonork: 100.1585880 Thanks Meter: 10 | hello & merry christmas first and for this thread i can say that is beautifull idea to create it so i wanna know how i can remove the old installed com in my pc i have 260 com instaled it's a virtual com i have setool box and u know to unlock the newest sony ericsson u must instal phone modem and any phone take a new com port so when i unlock 100 phones i must instal a new copy of windows so it's not good plz help me to fix this problem |
12-27-2008, 19:46 | #25 (permalink) | |
Insane Poster Join Date: Feb 2005 Age: 40
Member: 119664 Status: Offline Thanks Meter: 8 | Quote:
i dont understand you at all .. that guy wanted to make something good and after u come and make only funny things .. like what u know i know to but i dont make so much noise like you, it was his ideea so pls respect that if u mean what`s this .. Regards, and yes it will help lots of people | |
12-27-2008, 21:20 | #26 (permalink) | |
don't make useless posts. your level of stupidity reached 77% | |
12-28-2008, 07:59 | #27 (permalink) | |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Quote:
To uninstall COM Right click on my computer Click on properties click on Hardware Tab click on Device Manager Double click on Ports (COM & LPT) right click on any Virtual COM you want to delete and click on uninstall | |
The Following User Says Thank You to kasrawiz For This Useful Post: |
12-28-2008, 08:03 | #28 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | @Ahsan very funny .... are you totally time pass? don't tease peoples on forum they are humans like you and me! so please dont hurt any more! |
question about superdongle data of n-95 8gb | compue | Universalbox | 2 | 03-29-2010 15:16 |
One Question About Cruiser,pls | Gubby_J | Cruiser Suite | 2 | 03-29-2010 12:46 |
Palm Centro.. Question about Viewing your sd card on your pc | cesone | PalmOS /HP and others | 10 | 11-09-2008 08:04 |
Ask Yours Queries About Softwares | MAMAMOBILE | Nokia Multimedia | 67 | 08-28-2005 12:21 |
Question about a final error when flashing T610 using test point under Win XP | lilich62 | DIV | 0 | 07-22-2004 01:43 |
