Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc. |
12-13-2018, 20:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2015 Location: searching Age: 31
Member: 2424314 Status: Offline Thanks Meter: 731 | Convert GPT to MBR using command prompt (data loss) Step 1. Click “Win + R”, type “cmd” in the Run window. If you want to convert GPT to MBR during installing Windows, you can press “Shift + F10” to bring out command prompt. After you open the cmd window, type “diskpart.exe” and click “Enter”. Step 2. Type “list disk” and click ‘Enter“” Step 3.Type “select disk n” (n is the number of the disk you want to clean) Step 4. Type “clean” step 5.Type “select disk n” (n is the number of the disk you want to convert) Step 5. Type “convert mbr” Step 6. Type “exit” BEST REGARDS GSM PM SHA |
12-17-2018, 12:41 | #3 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | You can not convert the partition without going through the cleaning step, However, you can install a fresh MBR system without conversion, use refus software, and edit the settings to UFEi MBR...then create a bootable Usb flash drive, there are also some manual tricks to create Direct GPT or MBR partitioning systèms via Linux OS... |
The Following User Says Thank You to lyes_albert For This Useful Post: |
