Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Notebooks & Personal Computers
Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc.
Old 12-13-2018, 20:31   #1 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 731
Convert GPT to MBR using command prompt (data loss)
Step 1. Click “Win + R”, type “cmd” in the Run window. If you want to convert GPT to MBR during installing Windows, you can press “Shift + F10” to bring out command prompt. After you open the cmd window, type “diskpart.exe” and click “Enter”.
Step 2. Type “list disk” and click ‘Enter“”
Step 3.Type “select disk n” (n is the number of the disk you want to clean)
Step 4. Type “clean”
step 5.Type “select disk n” (n is the number of the disk you want to convert)
Step 5. Type “convert mbr”
Step 6. Type “exit”
BEST REGARDS
GSM PM SHA
The Following 2 Users Say Thank You to farooquepm For This Useful Post:
Old 12-17-2018, 12:30   #2 (permalink)
Crazy Poster
Member: 2861884
Thanks Meter: 14
without data loss how to do it
Old 12-17-2018, 12:41   #3 (permalink)
Member: 2669781
Thanks Meter: 1,839
You can not convert the partition without going through the cleaning step,
However, you can install a fresh MBR system without conversion, use refus software, and edit the settings to UFEi MBR...then create a bootable Usb flash drive, there are also some manual tricks to create Direct GPT or MBR partitioning systèms via Linux OS...
The Following User Says Thank You to lyes_albert For This Useful Post:
Old 12-17-2018, 14:51   #4 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 731
use paid software like erase us partition master etc
Page generated in 0.12863 seconds with 8 queries
