i have a dell d505 service tag cyjyf1j and a hitachi travel star hdd but cant get serial as it is starred out on the password entry screen and the one on the hdd is longer than 11 chars please help |
sorry service tag is cyjyf1j-595b |
bjd1pioy Possible HHD passwords: tkneuiqb jom95kcp YL9tQtPk7yagU0gf -zero between U and g as0bi9f8 -zero between s and b If none of those work, post actual hhd serial even if longer than 11 char. Passwords are for QWERTY keyboard only (standard US). Case sensitive. Some units only require pressing <enter> after password, some require pressing <ctrl>+<enter> after password and some require holding down <ctrl> while pressing <enter> once or twice. Good luck. |
thanks for your reply i have tried the ones you have suggested with no luck as asked here is the hdd serial number MPB2PAX2DM5R0G zero between r and g thanks |
elanl5l3 -small L between e and a, also between n and 5, also between 5 and 3- 0rmiax42 -begins with zero- If do not work, may be bad hard drive. But then I don't claim to know everything:) |
maybe hdd is bad then thankyou for all your help very appreciated will have to replace hdd |
85dqgq3u Enter this password, then holding CTRL push ENTER key twice. You will be disabled your admin password. Good luck! |
hello is it possible to unlock my laptop bios password, its a dell latitude E6320, system number BW707R1-1D3B, express service code 25891290685, thanks in advance |
Looks like your options are limited to either contacting Dell support (They can help you) Here: RouteTo or pay a commercial password site. Such as: Bios Password Removal | Bios Password Recovery But, be careful who you send money to. No matter which direction you decide to go, Please report back with who you used and your thoughts on their service. |
Dell Latitude E5500 Dell Latitude E5500 Service Tag: 2LDGXG1-2A7B Express Tag: 5645979217 BIOS Version: A09 Thanks in advance!! |
Bios password: LJK0TGMrhi3dm66c -zero between K and T Passwords are for QWERTY keyboard only (standard US). Case sensitive. Some units only require pressing <enter> after password, some require pressing <ctrl>+<enter> after password and some require holding down <ctrl> while pressing <enter> once or twice. Good luck. |
Thanks so much, worked greeeeeeeeeat!!! |
dell inspiron 1150 help hi I'm sorry because of the bad language I bought a dell inspiron 1150 laptop config enable password functional boot cd can not be Remove password possible? Member sevice CCPKB1J please someone help vj |
dmxcgr9m -This one should work, if not try next ones- 1fxqrmrb 0j6GpniR1bVIT0Fm -first char is zero, also zero between T and F- Passwords are for QWERTY keyboard only (standard US). Case sensitive. Some units only require pressing <enter> after password, some require pressing <ctrl>+<enter> after password and some require holding down <ctrl> while pressing <enter> once or twice. Good luck. |
