Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Notebooks & Personal Computers
Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc.
Old 08-28-2016, 05:53   #4861 (permalink)
Member: 224473
Thanks Meter: 15
Originally Posted by Maroc-OS View Post
purshased code does not work for my System Number.
Or maybe the admin password is diffirent then master password on E6440.
If Someone can help ll post them:
- System Number 1NKJYY1-1F66 and the purshased code rZa8JnV4dHz3CwLM
Thanks in advance.
Password is correct for that CODE, I even verified the code and it corresponds to a Latitude E6440.
You have a QWERTY keyboard layout, right?
Check the procedure, type password as is, paying attention to character cases (lowercase/UPPERCASE) and numbers, then hold down CTRL key and press ENTER twice (CTRL-ENTER-ENTER).
The Following User Says Thank You to drgn997 For This Useful Post:
Old 08-28-2016, 11:37   #4862 (permalink)
Member: 13188
Thanks Meter: 201
Thanks in advance.
Passwords for all kind of keyboard :
BRAND : DELL
HASH / (TAG) : 1NKJYY1-1F66
Password :
- ( qwerty ) : rZa8JnV4dHz3CwLM
- ( qwertz ) : rYa8JnV4dHy3CwLM
- ( azerty ) : rWq8JnV4dHw3CzL?
To accept password, hold CTRL button
and press ENTER key twice.
The Following User Says Thank You to Andrew_R For This Useful Post:
Old 08-29-2016, 12:27   #4863 (permalink)
Member: 2310150
Dell Inspiron 910
Service Tag : FJHHWF1
Express Service Code : 33829981021
HDD Password Protection.
Thanks. you.
Old 08-30-2016, 05:28   #4864 (permalink)
Member: 1908075
BRAND : DELL
Password :
Not working even with qwerty keyboard, please not i have an admin password set not am not stuck with blocked device, maybe the master key is not working on admin password.
Please if there is any solution cause i wan't to install another OS and i cant change the boot order and i don't wanna open the device to go with my second option usb boot.
Best.
Old 08-30-2016, 05:52   #4865 (permalink)
Member: 224473
Thanks Meter: 15
Best.
By Admin Password I understand that you are just locked out of Setup/BIOS, meaning that you are able to boot computer into Windows, if this is the case I've have had a few of similar cases, it's strange I know. What I usually do is that I go into Windows and install the Dell CCTK (Dell Client Configuration Tool Kit), this utility is used to SET a known System Password, so upon powering up the computer without pressing any key, it will show a screen similar to:
"This computer system: #1NKJYY1-1F66, is protected by a password authentication system..."
this is the best place where to use the master password, it will work on this screen!!, 99.9% sure.
Dell CCTK:
Dell Client Configuration Toolkit Application Driver Details | Dell US
Dell CCTK, Command Line Interface Guide:
http://downloads.dell.com/Manuals/al...uide_en-us.pdf
Once Dell CCTK is installed, from an "elevated" command prompt, you must type:
C:\>cd/
C:\>cctk --syspwd=<new-password>
<new-password>= replace it with an easy password, something that you won't forget just in case master password does not work, like: 11111111 (same character repeated 8 times):
C:\>cctk --syspwd=11111111
Once you've set the System Password you'll reboot the computer, don't press any key so it goes to the System Password prompt... now use the master password that you have.
drgn997
Old 08-30-2016, 09:50   #4866 (permalink)
Member: 2618331
Please. I need BIOS password for my 1F66
Pleaz i need your help
# 1N8HTZ1-1F66
Old 08-31-2016, 16:49   #4867 (permalink)
Member: 2618982
Hi guys,
I dont know if someone is able to help me, but I got a Dell latitude e5500 a couple days ago, but there's a bios password on it. I'm not able to figure out the password, so maybe you guys could help me.
Service tag is: GXLCC4J
Express service code is: 368-597-487-07
Your help would be much appreciated!
O I just found out that that the system number is GXLCC4J-1F5A
Old 09-07-2016, 12:50   #4868 (permalink)
Member: 2621739
latitude 3340
JPFR632-1F66
any help is appreciated. thank you in advance.
Old 09-08-2016, 22:58   #4869 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 265
latitude E5450
1RVJ662-1F66
THANKS
Old 09-10-2016, 15:32   #4870 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 165
I need dell passowrd help for dell 5340 any help here please ? thank
Old 09-11-2016, 07:28   #4871 (permalink)
Member: 1873660
Thanks Meter: 34
Please post Your Service Tag in appropriate format like other users
Old 09-11-2016, 23:05   #4872 (permalink)
Member: 2623568
Please help. Need the bios password for a Dell Latitude E5420.
4SJF5S1-1D3B
Thanks!
Old 09-12-2016, 06:28   #4873 (permalink)
Member: 1873660
Thanks Meter: 34
4SJF5S1-1D3B
Thanks!
4SJF5S1-1D3B
GNwQ5n9dVFK90FlD
G - GOLF ( UPPERCASE )
N - NOVEMBER ( UPPERCASE )
w - whisky ( lowercase )
Q - QUEBEC ( UPPERCASE )
5 - 5 ( digit )
n - november ( lowercase )
9 - 9 ( digit )
d - delta ( lowercase )
V - VICTOR ( UPPERCASE )
F - FOXTROT ( UPPERCASE )
K - KILO ( UPPERCASE )
9 - 9 ( digit )
0 - zero ( digit )
l - lima ( lowercase )
D - DELTA ( UPPERCASE )
IMPORTANT!
After typing your password, to accept press left CTRL key and holding this key Press Enter twice
Old 09-12-2016, 09:05   #4874 (permalink)
Member: 2623699
Hello, could you provide me with the bios password for a Dell latitude E5540 4SZCXZ1-1F66
Thanks in advance
Old 09-12-2016, 10:40   #4875 (permalink)
Member: 2623699
Thanks in advance
Forget that, someone came up with the corrrect password already
Page generated in 0.33400 seconds with 8 queries
