Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Notebooks & Personal Computers
Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc.
Old 09-10-2017, 21:59   #1 (permalink)
Damosco's Avatar
Member: 1803689
Sonork: 100.1659873
Thanks Meter: 123
External hard disk problem
Hi all please help me my external hard disk 1 to with 3 partitions is asking me to format 2 partitions before using it. I don't want to format because need my firmwares (phones firmwares) on it. The first partition can be open for about 15 seconds and after that disk unplug and plug alone asking to format the 2 others partitions. I tried CHKSDK command line and testdik but i not EXPERT and don't know what to do.
If someone can help me to recover my DATAS and after format it or repair it.Thank in advance
Old 09-11-2017, 19:00   #2 (permalink)
Moderator
Nishith's Avatar
Member: 1766148
Sonork: 100.1614494
Thanks Meter: 483
It seems your HDD got corrupted and might be physically damaged. In this case formatting the partition is the only option.
After formatting the Drive, You can try any good recovery software like GetDataBack, Recuva, EaseUS, etc. to recover your files.
But no one can give guarantee for the same. Some or may be lots of firmware/files which is recovered might be got corrupted in the format/recovery process.
If there is any Hardware issue, then you might not be able to recover your files easily.
For Better Chance of recovery, take care about few points:
1. Never write a single bit of data on the formatted drive which you want to recover.
2. Always do the deep scan in recovery for better chances of recovering the files without corruption.
3. Never Put recovered file Back to the Same HDD. Always copy recovered file to different HDD.
The Following User Says Thank You to Nishith For This Useful Post:
Old 12-20-2018, 13:51   #3 (permalink)
Member: 2318968
Thanks Meter: 4
Run liveOS and try copying in this shell :-)
Page generated in 0.27761 seconds with 7 queries
