Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Notebooks & Personal Computers
Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc.
Old 07-09-2016, 04:10   #16 (permalink)
Member: 2504337
Thanks Meter: 4
Does it work only on Elitebook? how about other HP laptops?
Old 07-09-2016, 10:04   #17 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
i've personally tested on a few elitebook and probook
Old 07-20-2016, 11:21   #18 (permalink)
Member: 1681600
thanks it really helped a lot to remove 6560b bios password!
Old 08-22-2016, 16:29   #19 (permalink)
Member: 1408281
hjælp har købt en hp elitebook folio 9470m mrd vin 7 wil nu have vin 8 ind og den kan ikke boote og låsen til bios har manden glemt...****kan nogle hjælpe
serie nr er cnu335912s
Old 09-19-2016, 10:26   #20 (permalink)
Member: 2626401
ProBook 6450b
HP ProBook 6450b is not supported in the tool. Any chance to reset the bios password for this type of notebook. Much appreciated!
Old 10-06-2016, 23:43   #21 (permalink)
Member: 7688
Sonork: klaus4
Thanks Meter: 2
can you unlocka 4540s or is it still listed and how to mak a bootable cd cause it cannot boot from usb.
thanks
Old 10-11-2016, 15:49   #22 (permalink)
Member: 8047
Hi
Can you help me to reprogram ( Product name ; Serial Number ........ ) in my Elitebook 8440p ?
Thanks
Old 10-24-2016, 08:42   #23 (permalink)
david laborator's Avatar
Member: 228601
Thanks Meter: 56
guys need help with my hp spectre x2 unlocking codes from
verizon usa imei 354019060177013
thanx in advance
Old 11-02-2016, 00:43   #24 (permalink)
Member: 2643960
Help to reset HP Probook 6560b bios password
Which model to select to reset the password using hbpr mozzif utility? I tried few similar models (6550b, 6450b, 6730b etc) but all says not supported...
The Following User Says Thank You to enkayjob For This Useful Post:
Old 11-21-2016, 09:54   #25 (permalink)
Member: 2650104
My HP Probook 6560b went blank after rseting bios password
Hi guys!
Please what can i do?
My HP Probook 6560b went blank while resetting the bios password using the HPBR mozzif utility.
Old 12-02-2016, 16:46   #26 (permalink)
Member: 2656169
Originally Posted by daves2ng View Post
Thank you guys here for your help. As a new member, i got solution to unlock my hp elitebook 8440p bios password and I was able to reprogramme the bios again.
Thank you
Me too. I just unlock elitebook 8440p. Finally
The Following User Says Thank You to Djoksi92 For This Useful Post:
Old 12-11-2016, 21:37   #27 (permalink)
Member: 392149
Thanks Meter: 199
HP 6570b probook bois password
Serial 5CB30621Z5
Product A3R37ES#ACQ
PCID A1029D1102
password plz
Old 12-13-2016, 16:07   #28 (permalink)
Member: 214244
Thanks Meter: 8
elite book folio 9470m CNU352FDCD password plz
Old 12-20-2016, 21:22   #29 (permalink)
Member: 147675
Thanks Meter: 2
It worked for my EliteBook 8440p, *** bless you! [beer]
Originally Posted by quasim0438 View Post
It contains a folder with utility to back up and re-image a usb thumb drive.
It contains an image (HPBR.IMG) of my usb thumb drive.
My image was made from a 64MB drive, but it compressed super awesome, so now the rar package is ~500KB. Your thumb drive needs to be 64MB or larger! After it is imaged, it will become 64MB in capacity (IE: a 1GB Drive will become 64MB), and may require Linux DD to restore true capacity, but that's outside the scope of this tool, I say it more for informational purposes. I have support for these 22 models. A supported model does not guarantee compatibility however. If you receive a 'Model not supported' error, please PM me with the error code number.
[SUPPORTED MODELS]
Elitebook 4310s Elitebook 2530p, Elitebook 4510s, Elitebook 6930p, Elitebook 8530w, Elitebook 8460p, Probook, 6550b, Probook 6535b, Probook 6730b, Probook 6735b, Probook 6460b, Probook 8730w, Probook 2230s, Probook 2560p, Probook 6455b, Probook 8560p, Probook 2730p Probook 8440p, Probook 8530p, Probook 8540w, Probook 2740p, Probook 8560w
[USE]
Once your thumbdrive has been imaged with HPBR.IMG, boot your HP Probook/Elitebook with the USB Thumbdrive. You will be presented with a menu:
HP PRO/ELITEBOOK BIOS PASSWORD RESET
(c)2014 Mazzif
PLEASE TELL ME YOUR MENU CHOICE
1] FIRST RUN? 4] ABOUT
2] SECOND RUN? 5] SHOTGUN
3] RE-PROGRAM 6] EXIT
Selection number:
The options are mostly self explanatory.
1] If first time using the tool, use this. Some models require a second run, and it will tell you if you need to run again. If so, then choose '2'
2] If program instructs you to reboot and run again
3] If you receive a white screen during POST about missing or invalid system board information, use this option to reprogram your board. It may ask for Serial Number, Part Number (SKU), Asset Tag number, or ConfigurationID (If asked for Config ID, use 25 0's (Twenty-Five Zeros)
4] About my work
5] SHOTGUN
Runs all keys. Good for testing models not on the list.
6] EXIT
Quit clean
Option 1 brings up a second menu where you then select your model:
HP PRO/ELITEBOOK FIRST RUN
1 Probook 6550b 12 Elitebook 4310s
2 Elitebook 2530p 13 Elitebook 4510s
3 Elitebook 6930p 14 Probook 6535b
4 Elitebook 8530w 15 Probook 6730b
5 Elitebook 8460p 16 Probook 6735b
6 Probook 6460b 17 Probook 8730w
7 Probook 2230s 18 Probook 2560p
8 Probook 6455b 19 Probook 8560p
9 Probook 2730p 20 Probook 8440p
10 Probook 8530p 21 Probook 8540w
11 Probook 2740p 22 Probook 8560w
Selection number:
Select the number that corresponds to your model and press Enter. The system will do the rest.
If prompted to run a 2nd time, boot to thumbdrive again, this time choosing option 2, and press enter. Again, you will have a model selection choice. Select the number that corresponds to your model again, and press Enter.
I don't know what else to say here. This is my first C program I've ever written, so there may be some unforeseen bugs. My final line count was 1162 lines of C. I used Open Watcom C v2 Compiler. So far I have been the only person to test, and I don't have all 22 models on hand, but 11 of the 22 I did, so I did physically test those, and they all worked awesome. If you hit a bug or snag, sorry, let me know and ill fix it.
I hope you find my work useful.
Old 01-02-2017, 23:24   #30 (permalink)
Member: 2251136
Elitebook 850 Bios / Admin pass
HP Elitebook 850 G2
Serie: 5CG6091VV6
Sku: G8T24AV
Bios / Admin password please! Can someone good fix this? Can pay a little for the right help
Page generated in 0.24551 seconds with 8 queries
