Hi I am trying this tools to reimage 4 GB USB but no result at USB and can't boot from my Laptop Elitebook 8440p, can you help Ahmed |
Hello, i have an 8460p elitebook, i tried to follow your procedure however i can not get the pc out of usb, because every time i try i ask bioss passwords. can you help me please? |
Does anybody have the new version of this? Becouse Mazzif had two version, the second version could unlock example xx70B laptops, for axample 6470B. Anybody have this file? |
I tried dos mode on HP EliteBook 8460p and received following error: "Failed to load defaults, error code: 89" Tried different modes, shotgun as well and still error 89. Any ideas on how to fix it? |
So pull out the battery (I mean the one on the motherboard) do not work anymore? |
And for EliteBook folio 9470m? |
HP ProBook 6460b supported but won't work Tried the MAZZIF tool and process on my HP 6460b but despite running through First Shot and Second Shot all I get at the end is: "This utility will not program for this SN: CNU22720LL" If anyone can help me resolve this? |
Thank you sir its work for me EliteBook 8460p |
its work , thank you sir |
Unlock hp elitbook 840 g1 bios password. NEED HELP TO UNLOCK HP ELITBOOK 840 G1 BIOS PASSWORD.....PLEASE HELP ME, PLEAS:confused::confused::confused::confused: |
Read eeprom and then I can help you . |
I also need help with my 8460p, after I pressed "Make Key", I get a explorer window opened with the newly created .exe file(called 8460PA,exe in the output folder). I can however not run the file since it apparently is an 16-bit application, which is impossible to run on my 64-bit Windows 7. What am I doing wrong? Do i have the wrong version of the program(it says v2,5)? Thanks in advance |
having a problem to do pass reset on elitebook 6930p i cant get into bios settings, not of them because always ask for admin password so i couldnt change boot priority to usb stick drive i wonder how many of you done this process with sucess??? if someone have an idea please let me know, or send me an email [email protected] thx in advance:cool::p |
HP Elitebook 8560w There is no listing for HP Elitebook 8560w, what can I do? |
first steep 1 u need usb drive windows now flag usb drive to loptop then start power then tick f9 to boot usb drive, but no usb drive windows display. dont worry tick ESC then after esc shows boot in first. just tick enter your loptop restart. after restar ur usb drive windows now reading.. |
