Windows password solution my friend forgot his windows password. please anyone with the solution on how to remove the password without lost any data should help. |
use hiren boot Sent from my SM-A510F using Tapatalk |
If your system partition is not encrypted with BitLocker or EFS, you can reset or recover the lost password using Ophcrack, PCUnlocker, Ubuntu or other live CDs. |
Just come across a trick that can enable the hidden administrator outside of Windows box. Hopefully this can help you get into admin account on your locked pc: 1. Boot from Windows install media. Press SHIFT + 10 when you reach the setup screen. 2. In the command prompt, type regedit, and then load the SAM registry hive. 3. Browse to the registry key: SAM\Domains\Account\Users\000001F4 4. Modify the F binary value by setting the byte at offset 0038 to 10. 5. Reboot and the hidden administrator will let you login. That's it! |
Brother just use pq magic .or trying cmd |
