06-05-2019, 08:57 | #1 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2711418 Status: Offline Thanks Meter: 28 | Iphone Activation Lock & FMI find my iphone Removal Service $12 and up so someone is getting them cheap I've seen as many as 1000 positive reviews for different sources The Second Source is a Mail in Source where they ask for the imei serial number of the device and the name of person to go to apple store ranges from $12 to 35 If anyone offers this as WholeSale Please let me know the prices offered are already cheap but as a dealer and buinsess man I'm always looking for cheaper and Faster Below is copy of booth services and there description ============================================= This is a service that will attempt to remove find my iPhone (iCloud) from your device. In order to do this, I need: Fresh only: if you used another service, it won’t work most likely. We can also see if a device has been attempted or not already. Phone number of the device. This is usually obtained by a carrier info service. This will have the number last used on the device. Without this, we cannot help. IMEI: this is self explanatory. I need this information in order to process your request. Name: if you don’t have this, it’s not 100% needed but always helps. Picture of the imei on the phone itself. Generally these process quickly. I have seen them instant but usually after 2-3 days it’s not going to work. If it doesn’t work, I will refund your money after the timeframe 100%. I am for great service and I’ll answer any questions you have. ========================================== The Second Source is a Mail in Source where they ask for the imei serial number of the device and the name of person to go to apple store ranges from $12 to 35 you are not located in the USA, do not message me. I can't help you!! Si ud. No esta ubicado en estados unidos, no me Habla, no le puedo ayudar. This service requires purchaser to visit an Apple Store in the USA ONLY. Pls note that this is for models 5 to XS-Max This is the highest quality iCloud removal available! You will know it and be impressed when you receive your letter! I personally guarantee this! Only devices with a clean iCloud status are eligible... we do not process lost/stolen device in iCloud status. The only way to know for sure is for me to check. iCloud status is different from blacklist/ESN/carrier status. THIS DOES NOT BYPASS KILL SWITCHED DEVICES (lost mode). This is different from the carrier lock which restricts the device to using a SIM card from a particular cellular carrier and has nothing to do with blacklist status which blocks certain devices from connecting to cellular carriers. You must be able to follow directions to use this service. #1 do not call apple. Do not email Apple. It will get you nowhere. You must visit apple in person for this to work. #2 Message me your device's IMEI numbers and I'll determine/check if your device is eligible for this service. We do not service all phones. Just the clean ones meaning not on lost/stolen iCloud status. #3 only once I’ve told you your device is in clean mode, you will receive further instructions. Limit 2. Make sure to type the name of the person going to the Apple Store and the imei of the device on the " message box " upon checkout, as well as the imei again. This is important. 4) You will receive the documents needed to get your device back up and running. Letter is usually mailed same day but if you don't include all required info with your purchase, letter will be mailed next day. Take the document to Apple. Tell the agent that you forgot the iCloud information of the device but you have the document in hand and the agent removes the iCloud information off the device. That is all you tell Apple. |
The Following User Says Thank You to repairs4you2 For This Useful Post: |
