HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
07-18-2014, 04:53 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2224435 Status: Offline Thanks Meter: 0 | HD 7 half touch screen Fix i need solution, maybe someone knows. Before repair HTC HD 7 LCD screen, touch screen was fine in fully working. After repair touch screen stop working properly, just half touch screen working. I believe something messed up in board, maybe someone know on which parts I need to be focus? p.s I even change new touch screen, same problem |
07-21-2014, 08:45 | #2 (permalink) | |
Junior Member Join Date: Jul 2014 Location: London, United Kingdom Age: 53
Member: 2226251 Status: Offline Thanks Meter: 0 | Quote:
I dont really think there is some problem in your board, I say this with some experience and also from the fact you stated, that half of it is working and the other half isnt. I have been in the mobile repair business for more than a decade now, and we often get customers facing this situation and in most and many cases the board is not the problem. What happens is LCD replacement is a sneaky affair and the repair workman needs to very cautious while assembling the display unit, if not done properly such problems do arise, did you visit a professional mobile repair unit? Thankyou. | |
07-22-2014, 21:08 | #3 (permalink) |
Member: 2224435 Status: Offline Thanks Meter: 0 | PeterPetrov Okay, thank you for your opinion and some your mobile business experience and id not even what... But still not get a problem solve solution. So, guys there is a thing working just half touch screen someone have any ideas where I should focus ? Maybe, I need check it out where electricity should pass throw to make sure there is nothing to do with wires or components contacts ? Thank you. Last edited by arturke; 07-22-2014 at 21:18. |
07-23-2014, 17:51 | #4 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 656666 Status: Offline Thanks Meter: 28 | check digitizer connector on board is soldier properly... Most likely its a problem with digitzer, replace it. |
The Following User Says Thank You to dj_mix For This Useful Post: |
