HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
12-15-2014, 11:20 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2152953 Status: Offline Thanks Meter: 1 | HTC M8 No sim detected i changed the simslot on a M8 hoping to restore function, but it did not work. The simslot is ok, the simcard is fine and in place. anybody know what the problem is? could it be software? i have literally no idea at this point, please help |
The Following User Says Thank You to black5757 For This Useful Post: |
12-17-2014, 10:50 | #2 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | no it can't be related what so ever to software thread moved to hardware |
The Following User Says Thank You to ~Leo~ For This Useful Post: |
05-02-2015, 12:36 | #4 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2136572 Status: Offline Sonork: 100.1653162 Thanks Meter: 41 | If the SIM slot is OK and all pins are connected to their points on the board>>> the problem is related to POWER IC . Try reheat it well and safely Good Luck |
07-31-2015, 17:30 | #6 (permalink) |
Insane Poster Join Date: Nov 2009 Location: oman
Member: 1164437 Status: Offline Sonork: 100.1659986 Thanks Meter: 23 | htc m8 sim not detected 100% solution just make this jumper.10000% work.enjoy it.follow the link. |
The Following 5 Users Say Thank You to naqvi66 For This Useful Post: |
02-15-2016, 07:40 | #9 (permalink) |
Junior Member Join Date: Dec 2015 Location: Boras, Sweden
Member: 2504814 Status: Offline Thanks Meter: 1 | naqvi66: i tried this and it helped me too. the phone i fixed had the issue but did work if the owner pressed on the phone (slightly below the sim card flex). |
03-18-2016, 01:40 | #10 (permalink) |
Member: 1164437 Status: Offline Sonork: 100.1659986 Thanks Meter: 23 | antalpromile,this me attested solution.this problem comes due to flex cable.check and connect jumper again.if problem still remain,then connect flex cable in mother board and check sim conecctor points ,is there any point open ?.if you get other open point ,tell me i will send you its diagramm or u can check and with other m8 |
