HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
03-12-2013, 22:11 | #46 (permalink) | |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | Quote:
I can fix it for you only by post for more information contact me [email protected] | |
03-13-2013, 00:15 | #47 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | the backlight is a hardware fault on the One-X PCB, tomorow i make a picture from LCD with backlight way and you can see it is a hardware fault .... |
The Following User Says Thank You to Benhure For This Useful Post: |
03-22-2013, 00:40 | #51 (permalink) |
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | have you an nvidia IC ? on the market we have 2 PCB's ... this problem on nvidia PCB is not a LCD or a Display problem, this is a PCB problem, anybody change the "coil's" or light IC, i change all on PCB and disamble a complete LCD to find the backlight line. Backlight works fine and all displays (3) have no faults. This is a problem from PCB. Bad Coils, Light IC or other faults on the PCB ... |
03-25-2013, 08:33 | #52 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Brisbane, Australia
Member: 1788854 Status: Offline Sonork: Mobile Fix Simple Thanks Meter: 16 | It is better to remove the battery in the first step, in order to avoid any short circuit and damage any parts. Cheers. |
05-10-2013, 07:12 | #54 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1886686 Status: Offline Thanks Meter: 0 | Hello guys I have the same problem I just replace in my htc one x the lcd with digitizer and I found this problem . I turn the phone on and I feel is on and touch the volume I can hear is working I feel vibrations but nothing on the screen , and also I try to find eny info about this problem my htc one x is from us att and there is some info about the lcd 3 diferent types Compatible: AT&T HTC One X yellow flex version and some 2 others i'm right? there is eny idea how can I fix this phone? I buy another logic board and still have the same problem :-( i'm in usa Houston tx. I appreciate eny Help Thank's in Adavance.. |
05-17-2013, 01:02 | #55 (permalink) |
Junior Member Join Date: May 2013
Member: 1939157 Status: Offline Thanks Meter: 0 | Hi everybody, I'm new here. I have the backlight problem, so I ordered some TPS65200YFFR IC samples from Texas. There exists the TPS65200YFFT on the site, I will have a problem if I use the TPS65200YFFR IC model? Not tested the coils, just want to change the IC. How do I remove it and put the new one? Can I remove the IC with a tweezers? I need to solder? Thanks in advance. |
05-17-2013, 16:02 | #56 (permalink) |
Junior Member Join Date: Mar 2011 Location: Romania
Member: 1539894 Status: Offline Thanks Meter: 2 | Hello, i have a problem with backlight on the one x, it's flickering and it's very dim when i use the phone. IF the phone is idle backlight is dim but not flickering, but if I stress the cpu, for example a benchmark, it flickers to almost no light at all. If I try to set the brightness in the settings menu it doesn't work, min and max are the same, no modification (very dim). Could this be an indication that the IC is broken ? Please read this post and give me an advice, thank you. Also, if someone has the IC please contact me , i want to buy at a fair price. |
05-22-2013, 06:18 | #57 (permalink) |
Junior Member Join Date: Mar 2009 Location: Chittagong, Bangladesh.
Member: 992723 Status: Offline Sonork: jamal0461 Thanks Meter: 4 | can any one please help me with htc one x lcd light problem. can u plz tell me where inductor if of this phone..thanks in advance |
The Following User Says Thank You to jamal0461 For This Useful Post: |
06-02-2013, 08:50 | #58 (permalink) | ||
Junior Member Join Date: Jun 2013
Member: 1951786 Status: Offline Thanks Meter: 0 | Quote:
I like to know if someone can confirm the correct value for "220" coil: Is 22uH (22 micro Henry) and VLF3010ST-220MR34 from TDK fits or is an 220 mH (mili Henry) I'm facing the same problem: blank screen after display+touchscreen replacement on my HOX. I chek the functionality for my phone through an usb-HDMI adapter, linked the HOX with my TV, I got pictures and everithing seems to be functional, including touchscreen but not the display. So i want to change the 220 coil to see if it will work, but I need the correct vallue. The aprox. dimenssions (measured) for 220 coil are: H=1,2 mm, and Diameter=3mm. The values are corresponding to TDK's VLF3010ST-220MR34 . Thank you in advance. | ||
06-09-2013, 15:40 | #59 (permalink) |
Major Poster Join Date: Dec 2011 Location: Sofia, Bulgaria
Member: 1705542 Status: Offline Thanks Meter: 10 | One bad Xperience Hi folks, I had some bad experience, with LCD exchange. When everything was assembled except the back panel, I tried to power on the phone to test is everything goes right. I hold up the battery pressed to chassis by hand, as it was not sticked to chassis (factory adhesive was not so sticky anymore). Few seconds after phone booted up, the screen starts flickering and after two flashes by backlight in max brightness it turned dimmed and stoped respond on manual brightness adjustment. So after some minutes of visual analysis I figured out what caused that. See attached picture explanation below. In my case only the 22uH (bigger one marked with 220) inductor was damaged, after exchanged it backlight was fixed. Regards, dailor Last edited by dailor; 06-09-2013 at 15:47. Reason: update |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
