HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
04-27-2015, 19:59 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2385668 Status: Offline Thanks Meter: 0 | HTC One X not power on or charge after new lcd I have tested the new lcd with a board from another One X and it works so the problem is definitely with the board from that phone. The guy i am doing it for says the charging port was a bit dodgy and that he had to wiggle the cable to get it to charge sometimes. Is the usb charging port linked to the power button, therefore if it is completely broken stopping the phone from powering on? Thanks |
05-04-2015, 20:52 | #7 (permalink) |
Junior Member Join Date: May 2015 Location: Europe
Member: 2389095 Status: Offline Thanks Meter: 0 | take a loaded battery, put it in, connect the display and the flex cable of the vibration and power it up. If its not vibrating you have a problem. If its vibrating, take a bright light and check the backlight. Try also to connect it to your PC, to see if itīs gettin recognized. |
