Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC Hardware repair
HTC Hardware repair HTC Hardware repair, tutorials, help, solutions
Old 09-24-2012, 04:15   #1 (permalink)
Member: 1776142
Htc One x strange backlight problem
Hey guys,
This is my first post on this forum. I have been reading a lot here and I find the information posted here very useful. I have a repair shop in Sydney, Australia.
Hope you guys can help me. A customer came to the shop with a cracked touch screen on a HTC One X and the backlight was working fine. I have worked on htc one x a lot of times. I took the motherboard out and tested a new LCD/touch assembly without replacing the cracked screen to make sure the new LCD/touch was working. When I did test it the backlight was working fine again. Then I went and replaced the touch/LCD and when I closed the phone to test the screen again there was no backlight.. I have tried other LCD/touch screens and backlight is still not working. How could I fix this problems?
Please advise
Thank you
The Following User Says Thank You to IT1989 For This Useful Post:
Old 09-24-2012, 05:48   #2 (permalink)
Member: 1788854
replace the inductor and coil next to the display ic. It willbe solved.
Old 09-24-2012, 05:59   #3 (permalink)
Member: 1776142
thanks so much for the reply.
Where is the inductor? location?
Thanks heaps mate
Old 09-24-2012, 06:54   #4 (permalink)
Member: 1776142
Managed to fix it by replacing the 220 coil by 2r2 coil on one x from an iPhone logic board
The Following 2 Users Say Thank You to IT1989 For This Useful Post:
Old 10-02-2012, 09:47   #5 (permalink)
Member: 241270
Its works thank you so much!!!!!!
Old 10-03-2012, 16:15   #6 (permalink)
Member: 66993
I have the same proble, can u show on picture which one I should to replace?
Old 10-04-2012, 15:18   #7 (permalink)
Member: 1788854
the back side, next to the Display IC, there are inductor and coil in the central area.
Old 10-05-2012, 02:11   #8 (permalink)
jr astigin's Avatar
Member: 757159
kindly show the pic of that parts thanks
Old 10-05-2012, 07:19   #9 (permalink)
cdma-india's Avatar
Member: 98139
here is pcd layout u can edit it where to make change and post it
thanks
Old 10-09-2012, 20:45   #10 (permalink)
Member: 805654
have same problem a picture would be very very very helpfull!
thanks in advance
Old 10-10-2012, 16:15   #11 (permalink)
Member: 1788854
Talking here is the solution of htc one x back light
Please do one by one! Your problem will be solved.
P.S. the mother board of One X is different with One XL. This Solution is for HTC ONE X ONLY!
The Following User Says Thank You to Mobile Fix Simple For This Useful Post:
Old 10-23-2012, 16:08   #12 (permalink)
Member: 1592618
Cool Same problem
same problem here with 2 One-x will try this solution and post the result, thanxXX
Old 10-24-2012, 13:21   #13 (permalink)
Member: 648760
Replace the coil with an inscription 220 with the coil from SE W880 with an inscription 220! To me helped!
Old 10-25-2012, 15:54   #14 (permalink)
Member: 1592618
Today I replaced the "220" coil with a "2R2" coil from an Iphone 3G like IT1989 said and IT WORKED too :-D
Old 12-03-2012, 16:28   #15 (permalink)
Member: 1846879
Need halp
Have a trouble with replacing the coil. When soldering the coil accidentally have been unsoldered a capacitor. Later, trying to solder the capacitor has finally lost it. Who can help identify capacitor?
Page generated in 1.47378 seconds with 11 queries
