Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC Hardware repair
HTC Hardware repair HTC Hardware repair, tutorials, help, solutions
Old 12-20-2012, 17:44   #16 (permalink)
Member: 1855899
htc one x
Originally Posted by Mobile Fix Simple View Post
replace the inductor and coil next to the display ic. It willbe solved.
the back side, next to the Display IC, there are inductor and coil in the central area.
Hi i have replaced 2 screens
1 started flickering and the backlight brightness was very low and the other didn't even worked except for the capacitive buttons who did i guess the touch did work but the backlight was faulty.
Could it have some connection with the componantes you mentioned or the screen compatillity.
Old 01-02-2013, 19:49   #17 (permalink)
Member: 1861479
Hello,
@ro10 you have resolved the problem?
Because I have the same problem...
Old 01-02-2013, 20:53   #18 (permalink)
Member: 21937
Originally Posted by tomatos666 View Post
Hello,
we all have same problem
same for me , tested 1 lcd ' working o.k , after install lcd , start flicking .... i changed other lcd , backlight was gone ....
waiting for backlight ic ...
Old 01-04-2013, 11:58   #19 (permalink)
Member: 1861479
Hello,
thanks for response.
I will try to change de IC and the coils.
But the coils are sure 220mH and 2,2mH? Is this Value to big?
And wher i can Buy all parts? (IC+Coils?)
Old 01-04-2013, 12:29   #20 (permalink)
Member: 1861479
Hello,
i have look in the Datasheet of the IC TPS65200.
In the Datasheet are a 10µH Coil on the LED and a second coil with 1µH on the Battery.
It´s possibile if the are on the Phone a 22µH and a 2.2µH coil?
On the second coil in the Phone are no sign.
Old 01-10-2013, 14:15   #21 (permalink)
issreedharsree's Avatar
Member: 1747026
Sonork: 1615193:sree
Unhappy Need help...
htc one x touch not work ....
i replace touch with lcd, but touch not work,
plz, tell me the touch screen ic in the motherboard,
thank adv...
Old 01-12-2013, 05:48   #22 (permalink)
Member: 1629668
Sonork: reinhard
this solution work.. it's also applicable in htc one v.. thank you
Old 01-17-2013, 17:11   #23 (permalink)
Member: 1869973
Hi guys. i am so not good at this but i can tell you that my motherboard is totally different! I don't know what to do. i am stuck if someone can please explain to me and guide me i will be more than grateful. Thanks !
Old 01-21-2013, 17:23   #24 (permalink)
Member: 1869032
mine is also different.
Can the US motherboard be fixed in this manner with the US iPhone components?
Old 01-22-2013, 09:35   #25 (permalink)
Member: 1832998
You can not repair it by yourself rush to a service center of htc or some professional electronic repair store.
Old 01-22-2013, 17:35   #26 (permalink)
Member: 859514
I had same issue and solved it this way . There is a small ic under metal shield betwen coil 220 and small flash ic that need to be reheated , now phone is working . I think changing coil only acidentaly does reheat this ic because i had changed coil with no sucess .
Old 01-24-2013, 16:05   #27 (permalink)
Member: 1873549
Sonork: 12345
Good time masters! I'm from Russia, I have no problem takaezhe backlight to ask help or replacement throttle it is certainly not vnem problem?
Sorry for pc karyavy google translation)
Old 01-24-2013, 23:35   #28 (permalink)
Member: 1873697
Dead Spots on Touch Screen
Hey Guys...
I'm having trouble finding any info on my problem, so I thought I'd tack my question on here...
Summary: Broken Screen on One X, Replaced Whole LCD/Touch and the whole middle was dead and wouldn't register a touch, replaced just the touch glass a second time, and now the whole bottom half and the home buttons don't register a touch... could this be Two faulty Touch Glass Units?? or is something wrong with the Motherboard... The Original Broken Glass still registers touches all over...
Any Help??
Old 01-24-2013, 23:37   #29 (permalink)
Member: 1873697
I've noticed if the LCD flex is not seated perfectly it flickers and goes on and off, and if I hold the phone hard where the flex plugs in (out of its casing) it also flickers... I'm no expert though, I'm just here looking for info on my dead touch areas...??
Old 01-26-2013, 22:06   #30 (permalink)
Member: 1760278
in the k750i a 2 220 coils...
Page generated in 0.21372 seconds with 11 queries
