HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
08-10-2016, 08:46 | #1 (permalink) |
Junior Member Join Date: May 2016 Location: Odesa
Member: 2573206 Status: Offline Thanks Meter: 13 | HTC Service Codes ## 775 # - EPST / PRL - PRL Settings ## 786 # - EPST - Status Menu ## 3282 # - EPST - Data Programming Menu (User Name, Advanced, Restore, Enable HFA, DSA Server, MMSC URL) ## 2539 # - EPST / A-Key - Data A key menu ## 7738 # - EPST / P_Rev - Protocol Revision ## 8626337 # - EPST / Vocoder - Unsure ## 33284 # - Debug - Debug Menu - (Debug Screen, Test Calls, RC Data, HDR / 1X Selection, Voice Privacy, DTMF Set, Korea Mode Set) ## 3424 # - Diagnostic - Connect to phone in diag mode ## 4772579 # - Reset the GPS ## 72 786 # - changes DSA back to Factory ## 889 # - enables TTY * # * # 34971539 # * # * - update firmwire * # * # 7594 # * # * - change the End Call / Power button action * # # * 273 283 * 663 282 * 255 * # * # * - code opens a File copy screen where you can backup your media files * # * # 197328640 # * # * - enter into Service mode * # * # 232339 # * # * - WLAN test (Use "Menu" button to start various tests) * # * # 526 # * # * - WLAN test (Use "Menu" button to start various tests) * # * # 528 # * # * - WLAN test (Use "Menu" button to start various tests) * # * # 7780 # * # * - Factory reset * 2767 * 3855 # - Factory Format * # * # 232338 # * # * - Shows WiFi MAC address * # * # 1472365 # * # * - GPS test * # * # 1575 # * # * - Another GPS test * # * # 232331 # * # * - Bluetooth test * # * # 232337 # * # - Shows Bluetooth device address * # * # 8255 # * # * - launch GTalk Service Monitor. * # * # 4986 * 2650468 # * # * - PDA, Phone, H / W, RFCallDate * # * # 1234 # * # * - PDA and Phone * # * # 1111 # * # * - FTA SW Version * # * # 2222 # * # * - FTA HW Version * # * # 44336 # * # * - PDA, Phone, CSC, Build Time, Changelist number * # * # 0283 # * # * - Packet Loopback * # * # 0 * # * # * - LCD test * # * # 0673 # * # * the OR * # * # 0289 # * # * - Melody test * # * # 0842 # * # * - Device test (Vibration test and BackLight test) * # * # 2663 # * # * - Touch screen version * # * # 2664 # * # * - Touch screen test * # * # 0588 # * # * - Proximity sensor test * # * # 3264 # * # * - RAM version - Was only able to get the following working on CM6 Rom - * # * # 4636 # * # * - Phone Information - "Phone information, Battery information, Battery history, Useage statistics, Wifi information" Confirmed not Working: ## UPST # - modem directory ## 778 # - EPST - Advanced Programming Unverified code: ## 37 872 # - Full Speed USB Mode - Enable / Disable ## 3386 # - DDTM - Enable / Disable * # 0011 # Service menu * # 0228 # Battery Status * # 2454 # Low Battery Power Off * # 0283 # Receiver Packet loopback * # 0782 # RTCTimeRead displays time (and seconds) * # 147852 # Allows you to access many screens including CDMA DATA Connections * # 369852 # Allows you to access many screens including CDMA DATA Connections * # 1472365 # GPS Setup * # 232331 # Bluetooth RF Test Mode * # 1575 # Service menu * # 197328640 # Service menu * # 2767 * 2878 # Service menu * # 32489 # Service menu * # 4238378 # Service menu * # 6984125 * # Service menu * # 7284 # Service menu * # 9090 # Service menu * # 2580 # Service menu * # 2664 # Touchscreen Firmware Version * # 2664 # Main Firmware Update * # 3264 # RAM Version * # 3282 * 727 336 * # Current Data State * # 745 # Sec_RIL_Dump allows you to copy to phone memory, clear ril log, (greyed out copy to SDcard and view RIL log), exit * # 7450 # Phone Dump Mode Disable * # 7451 # Phone Dump Mode Enable * # 7780 # Factory Reset * # 9900 # SysDump copy logcat / dumpstate / dumpsys, enable debug log * # 0 * # - Test Utility - SAFE TO PLAY WITH * # 0289 # Melody Test again? * # 0673 # Melody Test SAFE TO PLAY WITH * # 0842 # Vibration test SAFE TO PLAY WITH * # 2263 # ?? * # 2663 # Touchscreen Accuracy Test SAFE TO PLAY WITH * # 767 * 3855 # Factory Format - WARNING !!! mobile-manuals jimdo com/htc-codes/ |
