GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   HTC Hardware Repair (https://forum.gsmhosting.com/vbb/f796/)
-   -   need htc desire charging ways (https://forum.gsmhosting.com/vbb/f796/need-htc-desire-charging-ways-1627107/)
ddjadav 03-11-2013 18:33
hi
plz if any one provide me htc desire charging ways or schematic
thanks
sgobbotron 03-17-2013 09:45
Hi,
I also need the schematic because the charging paths near the USB plug are broken and I need to rewire.
I found some hi-res pics of the HTC Desire main board (link), can you suggest me where to fucus my searching?
Where are supposed to be connected the USB VCC and GND?
::GSM-27:: 03-18-2013 10:56
1 Attachment(s)
Originally Posted by ddjadav (Post 9261599)
hi
thanks
try this charge way poste result :) :)
sgobbotron 03-24-2013 22:35
3 Attachment(s)
Thank you very much, Maya!!!
Using your hints I fixed my phone and I post here some photo :)
Do you or somebody know where the USB data pins can be connected???
If I rewire also the data pins then my USB connector will back fully functional!
Thanks a lot!!!
mobile inn-gsm 03-29-2013 19:36
Nice work keep it up
::GSM-27:: 04-15-2013 17:47
Thanks a lot!!!
:) i need picture side pint conector to show you DATA cable TX-RX from usb
please remove "simcard & Sd card" slot ;) wen take picture
::GSM-27:: 04-15-2013 18:09
1 Attachment(s)
Thanks a lot!!!
worcking way htc disire ;)
M4MOHSIN 08-19-2013 11:32
thank you problem is solved
dead main 08-20-2013 21:59
thank you working for me
dgrei4 08-24-2013 04:40
Do not be too frequent charging, run out of power and then charge on the line, the battery can be removed to do with the universal charger, use a cell phone charger wife, try to control the charging of the length of time, or will drum up
NANDH 12-06-2016 09:00
We need HTC desire 210 changing ways it usb ways
Thanks
khanxxx 04-13-2017 09:26
I need htc desire D728 DUAL SIM charging ways
pls help
charging simble ok but no storrage :mad::mad:
iam changing battery & charing port bord same here
pls help brother
jaffar786 01-09-2019 12:02
htc 310 charging usb ways need help plzzz thanks 🙏
Page generated in 0.15879 seconds with 6 queries
