Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Hardware Repair
HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions
Old 03-11-2013, 19:33   #1 (permalink)
Member: 1540240
Thanks Meter: 14
need htc desire charging ways
hi
plz if any one provide me htc desire charging ways or schematic
thanks
Old 03-17-2013, 10:45   #2 (permalink)
Member: 1901647
Hi,
I also need the schematic because the charging paths near the USB plug are broken and I need to rewire.
I found some hi-res pics of the HTC Desire main board (link), can you suggest me where to fucus my searching?
Where are supposed to be connected the USB VCC and GND?
Old 03-18-2013, 11:56   #3 (permalink)
::GSM-27::'s Avatar
Member: 19423
Sonork: 69566
Thanks Meter: 245
Originally Posted by ddjadav View Post
hi
thanks
try this charge way poste result
The Following User Says Thank You to ::GSM-27:: For This Useful Post:
Old 03-24-2013, 23:35   #4 (permalink)
Member: 1901647
Thank you very much, Maya!!!
Using your hints I fixed my phone and I post here some photo
Do you or somebody know where the USB data pins can be connected???
If I rewire also the data pins then my USB connector will back fully functional!
Thanks a lot!!!
Old 03-29-2013, 20:36   #5 (permalink)
Member: 1728309
Sonork: mobile inn
Thanks Meter: 3
Nice work keep it up
Old 04-15-2013, 18:47   #6 (permalink)
::GSM-27::'s Avatar
Member: 19423
Sonork: 69566
Thanks Meter: 245
Thanks a lot!!!
i need picture side pint conector to show you DATA cable TX-RX from usb
please remove "simcard & Sd card" slot wen take picture
Old 04-15-2013, 19:09   #7 (permalink)
::GSM-27::'s Avatar
Member: 19423
Sonork: 69566
Thanks Meter: 245
Thanks a lot!!!
worcking way htc disire
The Following 2 Users Say Thank You to ::GSM-27:: For This Useful Post:
Old 08-19-2013, 12:32   #8 (permalink)
Member: 881000
Sonork: 100.1614181
Thanks Meter: 9
thank you problem is solved
Old 08-20-2013, 22:59   #9 (permalink)
Crazy Poster
Member: 2005215
Thanks Meter: 5
thank you working for me
Old 08-24-2013, 05:40   #10 (permalink)
Member: 1991998
Do not be too frequent charging, run out of power and then charge on the line, the battery can be removed to do with the universal charger, use a cell phone charger wife, try to control the charging of the length of time, or will drum up
Old 12-06-2016, 09:00   #11 (permalink)
Member: 1753063
Thanks Meter: 2
We need HTC desire 210 changing ways it usb ways
Thanks
Old 04-13-2017, 10:26   #12 (permalink)
Member: 1615884
Sonork: ferrarimzone
Red face I need htc desire D728 DUAL SIM charging ways
pls help
charging simble ok but no storrage
iam changing battery & charing port bord same here
pls help brother
Old 01-09-2019, 12:02   #13 (permalink)
Member: 1540254
Sonork: jaffar786
Thanks Meter: 3
htc 310 charging usb ways need help plzzz thanks 🙏
Page generated in 0.40314 seconds with 8 queries
