Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC Hardware repair
HTC Hardware repair HTC Hardware repair, tutorials, help, solutions
Old 08-22-2010, 08:49   #1 (permalink)
Member: 1375563
[URGENT] HTC Touch not charging
I tried putting in my friend's Touch's (HTC P3452, same model) charged battery, and my phone runs fine without any problem whatsoever. But it doesn't charge, not with his battery in, not with my battery in. I've tried different chargers and it just won't work! What can be the problem?
Please help. Thanks.
Old 08-22-2010, 18:45   #2 (permalink)
Member: 1375919
I have a HTC Touch pro and when the battery gets to hot (using it as navigation behind the windscreen of my car) it won't charge.
Old 08-22-2010, 20:35   #3 (permalink)
Member: 1375563
No that's not the issue I'm sure. I've waited a week before posting.
Can it be a faulty fuse?
BTW: Censoring Blo.w? Seriously? ;P
Old 08-23-2010, 19:46   #4 (permalink)
Member: 1375919
Well I'm not that aware of the inside of the HTC touch.
But a common problem with cellphones and PDA's are loose contact in the connector.
Because of the mechanical stress sometimes cracks appear in the solderjoints, resulting in pour connection or sometimes no connection at all.
You could try to resolder the connector to the PCB (best to use solder with lead)
Old 08-24-2010, 05:19   #5 (permalink)
Member: 1375563
[REF] Completely Disassemble the HTC Touch - xda-developers
Maybe this helps.
I'll try re soldering.
Old 08-26-2010, 13:37   #6 (permalink)
Member: 1375563
Tried Re Soldering, didn't fix it. What should I do! Any idea? Please help me
Old 08-27-2010, 15:41   #7 (permalink)
Member: 1375919
hmm did you try to replace the battery.
It's a lion battery, this means there is some electronics in it for protection, this could be broken.
Old 08-27-2010, 16:55   #8 (permalink)
Member: 1375563
As I mentioned, I've tried running the phone with another charged battery. Or charging mine with another HTC touch, and running it. It runs perfectly. The only problem with the phone is that it doesn't charge.
Old 08-29-2010, 09:54   #9 (permalink)
Member: 1375919
hmm.. I think the HTC Touch has a charger circuit build in, so I think you have to search there.
Unfortianlly I don't know much about the charger circuit of the HTC Touch, so I can't say where you have to look for.
Old 08-30-2010, 13:04   #10 (permalink)
Member: 1375563
Hmm. I have no idea either . Don't know what to do now.
I took it to HTC. They say they'd have to replace the whole motherboard to fix the problem, and it's WAY too expensive, even they don't recommend getting it done.
Old 08-31-2010, 14:51   #11 (permalink)
Member: 1375919
that's what the most companies do, replace the complet pcb.
What you could do is, take out the pcb, and lookup the function of every IC on google, maybe the charge circuit is build arround 1 IC, you could try to replace that one.
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 03-02-2000 21:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
NEED SW FOR 3210 5.01v URGENTLY!!!!! a33nick Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 01-10-2000 14:29
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.41092 seconds with 11 queries
