01-13-2020, 12:03 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | 1st World Condor Smart TV (U45-U49-U55) G7300 REPAIR DONE VIA eMMC 1st World Condor Smart TV (U45-U49-U55) G7300 REPAIR DONE VIA eMMC Log Operation: Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 004G60 Page size : 512 B Block size : 512 B Block count : 7733248 Size : 3776.00 MB --------------------------------------------------------------- CID Info CID : 1101003030344736300208A5285614D1 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 004G60 Product revision : 0.2 Product serial number : (hex) 8A52856 Manufacturing date : 01/2017 --------------------------------------------------------------- CSD Info CSD : D05E00320F5903FFFFFFFFE7924000E3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 5 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x0A) 00001010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1933312 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/004G60_13_01_2020_10_43_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.2; FW: 1.24. EXT_CSD saved to file F:/TV/HLS71EJI/(U45-U49-U55) G7300/EXT_CSD_13_01_2020_10_43_25.bin. Switched to boot area partition 1. Opening F:/TV/HLS71EJI/(U45-U49-U55) G7300/BOOT1_Toshiba eMMC 004G60_13_01_2020_10_44_21.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.2; FW: 1.24. Switched to boot area partition 2. Opening F:/TV/HLS71EJI/(U45-U49-U55) G7300/BOOT2_Toshiba eMMC 004G60_13_01_2020_10_45_04.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.2; FW: 1.24. Switched to user area. Opening F:/TV/HLS71EJI/(U45-U49-U55) G7300/FULL_DUMP_Toshiba eMMC 004G60_13_01_2020_10_45_27.bin file... Reading. Please wait... Done. Elapsed time 00:24:41 SW: 2.0.2; FW: 1.24. Switched to boot area partition 1. Added partition BOOT1 to constructor file. Switched to boot area partition 2. Added partition BOOT2 to constructor file. SRF "F:/TV/HLS71EJI/(U45-U49-U55) G7300/Condor_Smart TV (U45-U49-U55) G7300.srf" has been installed successfully. Last edited by DZGSM-TEAM; 01-13-2020 at 12:12. |
The Following 7 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
01-13-2020, 12:57 | #2 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | U45G7300 (Version Android: 4.4.4 Version Build: V1.00020) U49G7300 (Version Android: 4.4.4 Version Build: V1.00020) U55G7300 (Version Android: 4.4.4 Version Build: V1.00032) |
The Following 6 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
01-22-2020, 09:09 | #7 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | the same motherboard (The files are compatible with): Condor U55G7900 (Version Build: V1.00040) Condor U65G7900 (Version Build: V1.02000) Condor U86G8600 (Version Build: V1.00040) Condor U49G7800 (Version Build: V1.00047) (Version Build: V1.00049) Condor U55G7800 (Version Build: V1.00054) (Version Build: V1.00057) Condor U45G7300 (Version Build: V1.00020) Condor U49G7300 (Version Build: V1.00020) Condor U55G7300 (Version Build: V1.00032) Last edited by DZGSM-TEAM; 01-22-2020 at 09:17. |
The Following 2 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
