08-01-2018, 13:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Data extract [Answered] Please disconnect battery and USB cable. #red Model Settings:#blue Interface : eMMC #greenVoltage : 1.8V Bus Mode : 4 bits Bus speed : Auto Connecting... #blue ERROR[001]: Can not connect. No target device present. #redWhole proccess time: -185481524 ms. Please disconnect battery and USB cable. #red Model Settings:#blue Interface : eMMC #greenVoltage : 1.8V Bus Mode : 4 bits Bus speed : Auto Connecting... #blueDevice : Samsung eMMC QN16AB #greenPage size : 512 B #greenBlock size : 512 B #greenBlock count : 15269888 #greenSize : 7.28 GB (7456.00 MB) #green--------------------------------------------------------------- CID Info #blueCID : 150100514E313641420B1C44C6687233 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN16AB Product revision : 0.11 Product serial number : (hex) 1C44C668 Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info #blueCSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info #blueRevision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes #greenBoot1 size : 4096 Kbytes #greenBoot2 size : 4096 Kbytes #greenRPMB size : 512 Kbytes #green Partition config : (0x00) 00000000 #greenBoot partition enable : Device not boot enabled (default) #green(Bus width = 1Bit) #blueBoot ACK : No boot acknowledge sent (default) #green Boot bus conditions : (0x00) 00000000 #greenBoot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) #greenReset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) #greenBoot mode : Use single data rate + backward compatible timings in boot operation (default) #green RST_n function : (0x00) RST_n signal is temporary disabled (default) #green Partitioning support : Device supports partitioning features #greenEnhanced attribute : Device can have enhanced technological features in partitions and user data area. #greenMax enhanced data size: 3817472 Kbytes #greenPartitions attribute : 0x0 #greenPart setting completed: 0x0 #greenGP partition 1 size : 0 b #greenGP partition 2 size : 0 b #greenGP partition 3 size : 0 b #greenGP partition 4 size : 0 b #greenEnhanced area size : (0x0) 0 b #greenEnhanced area start : (0x0) 0 b #green ---------------------------------------------------------------Searching Android build info... Not found#red --------------------------------------------------------------- Backup EXT_CSD saved to file D:/CELSW/OCTOPLUS/MEDUSA PRO/EXT_CSD Backups/QN16AB_01_08_2018_14_07_00.bin. Connect successful. #green--------------------------------------------------------------- SW: 1.6.2; FW: 1.23. #blueWhole proccess time: -185444018 ms. Parsing device... Image size in bytes: 3523215360 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 3 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 3523215360 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 2 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Last edited by Octopus box; 08-01-2018 at 14:36. |
08-01-2018, 14:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. It is possible to extract data only for the phones with disabled option of files encryption (mostly for old devices). Most new/latest devices have enabled files encryption by default, so, unfortunately, extracting data from such devices are currently not possible. Full-disk encryption possibility is available and set by default from Android 5.0, please look here: https://source.android.com/security/encryption/, so if there is higher Android version then 5.0, this will be not possible to detect and extract data from this device. |
