12-02-2018, 22:24 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2225046 Status: Offline Thanks Meter: 1 | eMMC ''Connect'' button is inactive [Solved] P.S. I am using Octoplus Jtag 1.6.9. But the problem is the same on the Octoplus Jtag 1.7.0 Last edited by Octopus box; 12-03-2018 at 05:22. |
The Following User Says Thank You to aklay For This Useful Post: |
12-03-2018, 05:21 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
12-03-2018, 20:51 | #3 (permalink) | |
Member: 2225046 Status: Offline Thanks Meter: 1 | Quote:
Also I just noticed that in the bottom of software interface VREF and Box status is "not connected". Don't understan why. I am using windows 10 x64. Box worked on this system before. Also some times it says "No Smart-Card found! Program will now exit" | |
12-04-2018, 05:20 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have checked your screenshot and see, that the Box status is "not connected". This is the reason, why "Connect" button is not active. Box status is "not connected" means, that Box driver is not installed or installed incorrectly, or there is a problem with the Box HW and the Box is not detected correctly by OS. Please check which devices appear in Windows Device Manager when You connect Box to PC and whether all drivers are installed correctly. If necessary, re-install drivers. Also send us screenshot of Device Manager with devices, which appear in there when You connect Box to PC, we will check in details. |
12-04-2018, 23:12 | #5 (permalink) |
Member: 2225046 Status: Offline Thanks Meter: 1 | Could you please write me a guide step by step how install drives for Octoplus Pro Box (Samsung + LG + eMMC/JTAG Activated). So I will reinstall drivers and write you back about result. I am using windows 10 x64. Also I want to know that will this drivers work in the Linux syste or not? |
10-08-2020, 09:44 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, explain more detail. What exactly You're trying to do? |
