03-26-2019, 15:34 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | G531H possbile remove pin lock with jtag [Answered] Code: Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531H_DS SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G531H_DS_EMMC_BY_HELP-MI.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FN12MB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100464E31324D42008A8CC688B21D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FN12MB Product revision : 0.0 Product serial number : (hex) 8A8CC688 Manufacturing date : 11/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FN12MB_26_03_2019_16_30_45.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00400000) 4 MB P01: SBOOT (00400000, 00200000) 2048 KB P02: SBOOT2 (00600000, 00200000) 2048 KB P03: wfixnv1 (00800000, 00100000) 1024 KB P04: wfixnv2 (00900000, 00100000) 1024 KB P05: tdfixnv1 (00A00000, 00100000) 1024 KB P06: tdfixnv2 (00B00000, 00100000) 1024 KB P07: WDSP (00C00000, 00400000) 4 MB P08: MODEM (01000000, 00800000) 8 MB P09: MODEM2 (01800000, 00800000) 8 MB P10: TDDSP (02000000, 00400000) 4 MB P11: FOTA_SIG (02400000, 00100000) 1024 KB P12: wruntimenv1 (02500000, 00100000) 1024 KB P13: wruntimenv2 (02600000, 00100000) 1024 KB P14: tdruntimenv1 (02700000, 00100000) 1024 KB P15: tdruntimenv2 (02800000, 00100000) 1024 KB P16: PARAM (02900000, 00200000) 2048 KB P17: efs (02B00000, 01400000) 20 MB P18: prodnv (03F00000, 00500000) 5 MB P19: RESERVED2 (04400000, 00200000) 2048 KB P20: KERNEL (04600000, 01000000) 16 MB P21: RECOVERY (05600000, 01000000) 16 MB P22: PERSISTENT (06600000, 00100000) 1024 KB P23: persdata (06700000, 00900000) 9 MB P24: CACHE (07000000, 0C800000) 200 MB P25: SYSTEM (13800000, 5DC00000) 1500 MB P26: HIDDEN (71400000, 01E00000) 30 MB P27: userdata (73200000, 15E000000) 5.469 GB |
03-26-2019, 16:01 | #2 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Quote:
try to recover Data with content extrator then make fresh flash | |
03-26-2019, 17:52 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Unfortunately, we don't have any specific solution for remove pin lock with Octoplus Pro JTAG Software. |
