Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 01-19-2019, 13:22   #1 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 240
Thumbs up g532f dead boot repair Done medusa
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532F
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H8G4u
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : 90014A483847347592010427E04735A1
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H8G4u
Product revision : 0.1
Product serial number : (hex) 427E047
Manufacturing date : 03/2018
CSD Info
CSD : D02701320F5903FFFFFFFFE78A40002B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 393216
Number of sectors : 6307840
Device Manufacturer :samsung
Device Platform :mt6737t
Build ID :MMB29T
Display Build ID :MMB29T.G532FXWU1APK6
Release ID :6.0.1
Device Model :SM-G532F
Device Name :grandpplteser
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :grandpplteser-user 6.0.1 MMB29T G532FXWU1APK6 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_19_01_2019_16_11_34.bin.
Connect successful.
SW: 1.7.3; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: nvram (00004000, 00004000) 8 MB
P03: lk (00008000, 00001000) 2048 KB
P04: BOTA1 (00009000, 00001000) 2048 KB
P05: secro (0000A000, 00003800) 7 MB
P06: seccfg (0000D800, 00000400) 512 KB
P07: efuse (0000DC00, 00000400) 512 KB
P08: tee1 (0000E000, 00003000) 6 MB
P09: BOTA2 (00011000, 00003000) 6 MB
P10: EFS (00014000, 00004000) 8 MB
P11: nvdata (00018000, 00010000) 32 MB
P12: PARAM (00028000, 00004000) 8 MB
P13: recovery (0002C000, 00008000) 16 MB
P14: boot (00034000, 00008000) 16 MB
P15: md1img (0003C000, 00010000) 32 MB
P16: md1dsp (0004C000, 00002000) 4 MB
P17: keystore (0004E000, 00004000) 8 MB
P18: omekeystore (00052000, 00001C00) 3584 KB
P19: proinfo (00053C00, 00001400) 2560 KB
P20: para (00055000, 00000400) 512 KB
P21: PERSISTENT (00055400, 00000400) 512 KB
P22: STEADY (00055800, 00000800) 1024 KB
P23: protect1 (00056000, 00004000) 8 MB
P24: protect2 (0005A000, 00004000) 8 MB
P25: RESERVE2 (0005E000, 00002000) 4 MB
P26: system (00060000, 00604000) 3080 MB
P27: cache (00664000, 000C8000) 400 MB
P28: hidden (0072C000, 0001E000) 60 MB
P29: userdata (0074A000, 00744000) 3720 MB
Switched to boot area partition 1.
Erasing. Please wait... Done.
Switched to boot area partition 2.
Disconnected.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532F
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Build ID :MMB29T
Release ID :6.0.1
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_19_01_2019_16_12_11.bin.
Connect successful.
Please select file.
Please select file.
Please select file.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf".
Write data verification is enabled.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing BOTA0 partition... Done.
Writing lk partition... Done.
Writing BOTA1 partition... Done.
Writing secro partition... Done.
Writing seccfg partition... Done.
Writing efuse partition... Done.
Writing tee1 partition... Done.
Writing BOTA2 partition... Done.
Writing EFS partition... Done.
Writing PARAM partition... Done.
Writing recovery partition... Done.
Writing boot partition... Done.
Writing md1img partition... Done.
Writing md1dsp partition... Done.
Writing keystore partition... Done.
Writing omekeystore partition... Done.
Writing proinfo partition... Done.
Writing para partition... Done.
Writing PERSISTENT partition... Done.
Writing STEADY partition... Done.
Smart Repair is successfully complete.
Disconnected.
The Following User Says Thank You to GSM KPK For This Useful Post:
Page generated in 0.22665 seconds with 7 queries
