01-11-2017, 14:54 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Bulgaria,Plovdiv Age: 53
Member: 77040 Status: Offline Thanks Meter: 60 | GT-I9195 Sandisk eMMC cannot write I have 4 pcs board of Galaxy S4 mini GT-I9195 and 1pcs GT-I9192 with same Qualcom MSM8930AB CPU and Sandisk SDIN7DU2 eMMC. When I try to connect with Octoplus Pro JTAG Software 1.2.9 can not connect with Auto detect but when I choose manualy MSM8930AB all is ok. Problem is ; i can read emmc but cannot write nothing example : for GT-I9192 When I rty "'Repair Samsung device using factory files'' i choose CSB_signed_SERRANODS_ONEPIT_OPEN_130523.pit and I9192UBUCOC2_I9192ZTOCOC1_I9192UBUCOC2_HOME.tar.md 5 Box says; Selected pit file: G:/Smartphones/Samsung/GT-I9192/CSB_signed_SERRANODS_ONEPIT_OPEN_130523.pit Open file "G:/Smartphones/Samsung/GT-I9192/I9192UBUCOC2_I9192ZTOCOC1_ZTO/I9192UBUCOC2_I9192ZTOCOC1_I9192UBUCOC2_HOME.tar.md 5". Writing PIT Writting. Please wait... Writting partition MODEM... Read/write verification error. Possible reasons: damaged or write protected eMMC. JTAG device has been disconnected. Disconnected. same is happen with other boards GT-I9195 Dou you have a Idea what is wrong in this case. may be unsupportet eMMC or .... |
01-11-2017, 15:02 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-11-2017, 15:06 | #3 (permalink) |
Member: 77040 Status: Offline Thanks Meter: 60 | Here is full log Connecting... Vref level is 1.79V. Scan successfull, number of TAPs = 2. TAP 0: Id code = 4BA00477, IR length = 4. TAP 0: CPU name "Unknown", interface type = 0. TAP 1: Id code = 308A30E1, IR length = 11. TAP 1: CPU name "Qualcomm MSM8930AB", interface type = 9. Enabling ARM Core... ERROR032 Initializing interface... JTAG speed : Auto (RTCK) Protocol ver : 3.0 Buffer size : 0x10040 bytes Storage type : eMMC Storage ID : 0045:0001 Storage size : 7456 MB Device : Sandisk eMMC SEM08G Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB Connect successful. --------------------------------------------------------------- SW: 1.2.9; FW: 1.1.0. Selected pit file: G:/Smartphones/Samsung/GT-I9192/CSB_signed_SERRANODS_ONEPIT_OPEN_130523.pit Open file "G:/Smartphones/Samsung/GT-I9192/I9192UBUCOC2_I9192ZTOCOC1_ZTO/I9192UBUCOC2_I9192ZTOCOC1_I9192UBUCOC2_HOME.tar.md 5". Writing PIT Writting. Please wait... Writting partition MODEM... Read/write verification error. Possible reasons: damaged or write protected eMMC. JTAG device has been disconnected. Disconnected. |
01-11-2017, 15:17 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, device was connected successfully, so most likely, this is HW issue (damaged or write protected eMMC) and Software can't write data correctly into device. Try to uncheck "Write data verification" option in Software and make Factory repair again without verification (most likely this will not help, but You can try). |
01-11-2017, 15:44 | #5 (permalink) |
Member: 77040 Status: Offline Thanks Meter: 60 | I unchecked "Write data verification" and write starting but after 14Mb Error here is log Selected pit file: G:/Smartphones/Samsung/GT-I9192/CSB_signed_SERRANODS_ONEPIT_OPEN_130523.pit Selected firmware file: G:/Smartphones/Samsung/GT-I9192/I9192UBUCOC2_I9192ZTOCOC1_ZTO/I9192UBUCOC2_I9192ZTOCOC1_I9192UBUCOC2_HOME.tar.md 5 Open file "G:/Smartphones/Samsung/GT-I9192/I9192UBUCOC2_I9192ZTOCOC1_ZTO/I9192UBUCOC2_I9192ZTOCOC1_I9192UBUCOC2_HOME.tar.md 5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Writting. Please wait... Writting partition MODEM... ERROR[007]: Command fail. At sector 43392 Probably eMMc is Gone? Is there a way to back to life these devices |
01-11-2017, 15:54 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
If You have Medusa Pro Box and have eMMC pinout for this device, You can try to replace proper eMMC and try to make Repair again. | |
01-11-2017, 16:09 | #8 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | any software or box will not write data to emmc if firmware corrupted or write protection become on...... as my information there is no any box supported write firmware of sandisk emmc,,,,,, in that condition you must replace emmc with new one to solve you phones |
The Following User Says Thank You to chand_gee For This Useful Post: |
01-11-2017, 16:11 | #9 (permalink) | |
Please look here: https://gsmserver.com/item/boxes-and...o-upgrade-kit/. | |
01-12-2017, 07:27 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | You can use Samsung eMMC chip with same size (8 GB) for replacement. |
