Member: 1784601
Thanks Meter: 21 | Quote:
Originally Posted by Octopus box As You can see from Software log:
but accordingly to Live Log, should be the following:
Please set necessary eMMC boot settings ("eMMC service" tab, "Boot operation mode" button), then select "Boot Partition Area 1" option in Software and write "SAMSUNG GT-I9300 (BOOT1).BIN" from the Support Area. After this do "Smart Repair". Post here full Software log with all of these operations. | Quote:
| How to set? I will post an image.
I've tried to leave it with the parameter on the screen, then I write Boot Partition Area 1 and then do a Smart Repair.
The writing happened successfully.
I will post you a LOG. Quote:
Welcome to Medusa Pro Software version 1.5.0.
Started.
Reader #0: Broadcom Corp Contacted SmartCard 0
Reader #1: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-I9300
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9300_EMMC.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Device : Samsung eMMC VTU00M
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 15010056545530304DFC3D39868641FB
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : VTU00M
Product revision : 15.12
Product serial number : (hex) 3D398686
Manufacturing date : 04/2014
CSD Info
CSD : D02701320F5903FFF6DBFFFF8E40406D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default) (Bus width = 4Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7659520 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x1
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/VTU00M_23_12_2017_13_37_06.bin.
Connect successful.
SW: 1.5.0; FW: 1.22.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: PARAM (00010000, 00004000) 8 MB
P05: BOOT (00014000, 00004000) 8 MB
P06: RECOVERY (00018000, 00004000) 8 MB
P07: RADIO (0001C000, 00010000) 32 MB
P08: CACHE (0002C000, 00200000) 1024 MB
P09: SYSTEM (0022C000, 00300000) 1536 MB
P10: HIDDEN (0052C000, 00118000) 560 MB
P11: OTA (00644000, 00004000) 8 MB
P12: USERDATA (00648000, 016D2000) 11.41 GB
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/VTU00M_23_12_2017_13_37_50.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-I9300
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/VTU00M_23_12_2017_13_38_04.bin.
Connect successful.
Switched to boot area partition 1.
Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG GT-I9300 (BOOT1).BIN file...
Write data verification is enabled.
Writing. Please wait... Done.
Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9300_EMMC.srf".
Writing GPT partition... Done.
Writing BOTA0 partition... Done.
Writing BOTA1 partition... Done.
Writing EFS partition... Done.
Writing PARAM partition... Done.
Writing BOOT partition... Done.
Writing RECOVERY partition... Done.
Smart Repair is successfully complete.
SW: 1.5.0; FW: 1.22. | After that, I have read again the emmc, and here is a log. Quote:
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-I9300
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/VTU00M_23_12_2017_13_43_48.bin.
Connect successful.
P12: USERDATA (00648000, 01710000) 11.53 GB
| I think isn't good, because you told me that I should find
Partition config : 01001000
Boot partition enable : Boot partition 1 (Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
but I already have
Boot ACK : No boot acknowledge sent (default) |
