01-10-2018, 09:06 | #1 (permalink) |
Junior Member Join Date: Apr 2013 Location: Mashhad Age: 33
Member: 1924303 Status: Offline Thanks Meter: 7 | How to Unbrick HTC M9 0PJA100 [Answered] I Have A HTC M9 0PJA100 and when connected to PC showing qualcomm 9008 driver . How To Solve This problem I Have a medusa pro box. Thank All. Please Reply This Last edited by Octopus box; 01-10-2018 at 10:49. |
01-10-2018, 10:49 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello Repairing of this device is currently not supported, but supported repairing of HTC M9 OPJA200 via eMMC. Please check, whether eMMC pinout for your device revision (OPJA100) is the same as eMMC pinout for supported OPJA200. If they are the same, try to solder all necessary wires and connect the device. If device will be connected successfully, try to repair it as OPJA200. |
01-10-2018, 16:12 | #3 (permalink) |
Member: 1924303 Status: Offline Thanks Meter: 7 | This Problem Showing too me !!! Model Settings: Interface : eMMC Brand : HTC Model : One_M9_0PJA200 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : 8 MHz Connecting... Device : Unknown eMMC M MOR Page size : 512 B Block size : 512 B Block count : 3848192 Size : 1879.00 MB --------------------------------------------------------------- CID Info CID : 65646F4D204D4F5212A0000006154445 Manufacturer ID : 0X65 Device/BGA : Device (removable) OEM/Application ID : 0X6F Product name : M MOR Product revision : 10.0 Product serial number : (hex) 615 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D07FFF320F59007FF6DB80001E40001D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 131072 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M MOR_10_01_2018_18_37_34.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. |
01-10-2018, 16:48 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Also, the problem is with eMMC chip: Quote:
05-16-2018, 18:15 | #5 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | Model Settings: Interface : eMMC Brand : HTC Model : One_M9_0PJA200 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_16_05_2018_22_14_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. help |
05-17-2018, 05:14 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Help what? What is your device model exactly? What is the state/problem with your device? What did You try to do with the device? Where is log of performed operations? |
05-17-2018, 17:01 | #7 (permalink) |
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | this device is 0pja200 and not partation in it rom1 failed when i flashed on it rom2 and rom3 write well but rom1 have partation but not flashed on it .what can i do ? |
05-18-2018, 04:42 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please post here full Software log with all of performed operations with the device, we will check. Also read and always follow these rules: http://forum.gsmhosting.com/vbb/f664...leted-2165828/, http://forum.gsmhosting.com/vbb/f62/...rules-1591101/. |
05-19-2018, 09:04 | #9 (permalink) |
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | HTC M9 0PJA200 HELP ME Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_19_05_2018_12_57_44.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.SRF". Write data verification is enabled. Writing GPT partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_19_05_2018_12_59_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_19_05_2018_12_59_48.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.SRF". Write data verification is enabled. Writing GPT partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_19_05_2018_13_00_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.SRF". Write data verification is enabled. Writing board_info partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4e Page size : 512 B Block size : 512 B Block count : 61079552 Size : 29.13 GB (29824.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484247346505072F44C873421F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4e Product revision : 0.7 Product serial number : (hex) 2F44C873 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HBG4e_19_05_2018_13_01_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Partition table was not found. Partition table is not found. Disconnected. Disconnected. |
05-19-2018, 09:06 | #10 (permalink) |
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | SW: 1.5.8; FW: 1.23. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/HTC_ONE_M9_0PJA200_EMMC.SRF". Write data verification is enabled. Writing board_info partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. |
05-19-2018, 09:14 | #11 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
