12-30-2016, 03:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 339 | HTC one M7 (PN07140) HS-USb QDloader mode can be fix with octiplus jtag? when i connect to phone i can see this on comport if yes can u plz tell me how can we fix this phone thanks |
01-03-2017, 09:29 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Repairing of HTC one M7 (PN07140) is supported via JTAG in Octoplus JTAG/Medusa Software. To repair this device, do the following: 1. Install the latest version of Octoplus JTAG/Medusa Software (Software). 2. Select model "HTC one M7 (PN07140)" in Software list and press "Help" button to look at JTAG pinout picture and to read repair manual. 3. Solder all necessary JTAG wires. 4. Connect the device. 5. Select "EasyRepair Mode", press "EasyRepair" button and follow repair wizard instructions. |
01-09-2017, 05:29 | #3 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 339 | HTC one M7 (PN07140) HS-USb QDloader mode can be fix with octiplus jtag? Quote:
not working the way u say my phone on hs-usb mode like some lg phone have problem can not turn on but when u put usb cable and connect to computer it show hs-usb mode See my pic I already try u can see phone also connect when I put USB cable Last edited by MUTUAL; 01-09-2017 at 05:35. | |
01-09-2017, 11:07 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Most likely, You have soldered some of JTAG wires incorrectly. Please check soldering of all JTAG wires, make them as short as possible (max. 3-5 CM length) and try to connect again. If You are sure You soldered all wires correctly, but the device still not connects, maybe JTAG is closed in this device or this phone has HW issue. |
01-09-2017, 23:43 | #5 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 339 | Quote:
ok tell me when i to solder jtag wire i need to connect battery do i also need to plug usb cable? i try both way plug usb cable and unplug usb cable same problem also when i sect file it always asking me to enter imei even i dont want to change any imei i think u need to fix this option if we dont want to change imei should have skip option,in this software i must put imei then i can press next button. and we need solution if phone can connect to hs-usb mode should have other option we can flash or try without soldering wire like some phone lg we doing without soldering wire | |
01-10-2017, 08:30 | #6 (permalink) | ||||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
