11-13-2017, 09:22 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Mian Channun,Panjub,Pakistan Age: 34
Member: 1827333 Status: Offline Thanks Meter: 64 | Huawei G630-U10 Dead Boot Repair Done Model Settings: Interface : eMMC Brand : Huawei Model : G630-U10 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/HUAWEI_G630-U10_EMMC_SMALL.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447316404030BA2FA3332B5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.3 Product serial number : (hex) BA2FA33 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G1d_13_11_2017_13_08_16.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.8; FW: 1.22. P00: GPT (00000000, 00000022) 17 KB P01: sbl1 (00000022, 00000400) 512 KB P02: sdi (00000422, 00000040) 32 KB P03: DDR (00002000, 00000040) 32 KB P04: rpm (00004000, 000003E8) 500 KB P05: tz (000043E8, 000003E8) 500 KB P06: aboot (000047D0, 00002BB0) 5.461 MB P07: pad (00007380, 00000800) 1024 KB P08: oeminfo (00007B80, 00020000) 64 MB P09: modemst1 (00027B80, 00002000) 4 MB P10: modemst2 (00029B80, 00002000) 4 MB P11: modem (0002C000, 00030000) 96 MB P12: fsg (0005C000, 00002000) 4 MB P13: fsc (0005E000, 00000002) 1024 b P14: ssd (0005E002, 00000010) 8 KB P15: log (0005E012, 00010000) 32 MB P16: bkbootup (00070000, 00020000) 64 MB P17: persist (00090000, 00004000) 8 MB P18: boot (00094000, 00006000) 12 MB P19: recovery (0009A000, 00008000) 16 MB P20: cust (000A2000, 00080000) 256 MB P21: cache (00122000, 00060000) 192 MB P22: misc (00182000, 00002000) 4 MB P23: system (00184000, 00200000) 1024 MB P24: userdata (00384000, 00200000) 1024 MB P25: grow (00584000, 001DBFDF) 952 MB Repairing from file "C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/HUAWEI_G630-U10_EMMC_SMALL.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing sdi partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing modem partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing bkbootup partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing cust partition... Done. Writing misc partition... Done. Smart Repair is successfully complete. SW: 1.4.8; FW: 1.22. Disconnected. Last edited by Octopus box; 11-13-2017 at 09:58. |
The Following 4 Users Say Thank You to ayan_mobiles For This Useful Post: |
04-26-2018, 11:40 | #2 (permalink) |
Freak Poster Join Date: Jun 2017 Location: SAUDI ARABIA RIYADH
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | G630-U10 Huawei Dead Boot Repair Done With OctoPlus Jtag Pro but not open only show qualcomm port how to fix i try to flash with qfil tool no cash |
The Following User Says Thank You to wahiditunes For This Useful Post: |
04-26-2018, 11:44 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | At first please post here full Software log with the "Connect" and "Repair" operations, we will check. |
04-26-2018, 11:47 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | The boot repair files you used with Octopus JTAG box can be older than your phone had before so i think you need a full firmware with the same version you had in your phone or newer |
The Following User Says Thank You to gulshan-iqbal For This Useful Post: |
