03-19-2018, 17:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Algeria Age: 42
Member: 56311 Status: Offline Thanks Meter: 273 | Huawei G630-U10 eMMC connect question [Answered] Interface : eMMC Brand : Huawei Model : G630-U10 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/HUAWEI_G630-U10_EMMC_SMALL.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Sandisk eMMC SEM04G Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 45010053454D3034473C34B15599B1C7 Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SEM04G Product revision : 3.12 Product serial number : (hex) 34B15599 Manufacturing date : 11/1998 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFDFF8A4040A7 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 2048 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 98304 Kbytes Partitions attribute : 0x8 Part setting completed: 0x8 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 64 MB GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0xEFA95800) 3835 MB ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/SEM04G_19_03_2018_17_40_32.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, BD7020006020) 9.932e+07 GB Last edited by Octopus box; 03-20-2018 at 06:00. |
03-19-2018, 18:14 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
