Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 08-29-2019, 17:38   #1 (permalink)
Member: 430749
Thanks Meter: 24
I9195 EMMC repair? [Answered]
read info ok:
Welcome to Octoplus Pro JTAG Software version 1.7.7.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-I9195
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9195_EMMC.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Sandisk eMMC SEM08G
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : 45010053454D3038479001749AC531B7
Manufacturer ID : 0X45
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : SEM08G
Product revision : 9.0
Product serial number : (hex) 1749AC5
Manufacturing date : 03/2014
CSD Info
CSD : D00F00320F5903FFFFFFFFFF92404011
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 10 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Erase block size : 4096 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3768320 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/SEM08G_29_08_2019_13_28_37.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
smart repair fail:
Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9195_EMMC.srf".
Write data verification is enabled.
Writing GPT partition...
Write verification error 1. Possible reasons: damaged or write protected eMMC.
Disconnected.
remove write protect erro:
Remove write protect error.
Disconnected.
Old 08-30-2019, 06:48   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Please, check Software log:
Please, try to disable this option and repeat operation again, after post here full Software log
Page generated in 0.20282 seconds with 8 queries
