04-13-2017, 13:44 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Poland Age: 45
Member: 19001 Status: Offline Thanks Meter: 45 | I9300 emmc data recovery I need help with data recovery from emmc chip. It comes from i9300. I need to recover pictures, contacts. I'm getting this log: Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 33554432 Size : 16.00 GB --------------------------------------------------------------- CID Info CID : 1501003030303030305620110726589D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20110726 Manufacturing date : 05/2021 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DBFFEF8A404023 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4026531840 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/000000_13_04_2017_14_41_50.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. And can't acces to data on content extractor. B.R On content extractor i'm getting: Didn't find any user partition. |
04-13-2017, 13:59 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. This message means, that Software didn't find partitions on eMMC chip (most likely, they are erased or damaged), so it is impossible to recognize any data for recovering. As You can see, eMMC chip has problems: Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
