09-15-2019, 08:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | IMPROVED CONDOR TAB TRA-901 V2014 REPAIR DONE VIA eMMC [IMG]****************************/convkey/8e12/om8kq3wzkjw64fszg.jpg?size_id=4[/IMG] IMPROVED CONDOR TAB TRA-901 V2014 REPAIR DONE VIA eMMC BY SWEET OCTOPLUS [IMG]****************************/convkey/b7e9/7f7coxccx6ezvwkzg.jpg[/IMG]LOG INFO : Code: Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : CONDOR Model : TRA-901G_V2014 SRF : E:/SRF STARKRIMES/CONDOR/CONDOR_TRA-901_EMMC_SRF/CONDOR_TRA-901_VERSION 2014_eMMC_SRF/VERSION 2014/Condor_TRA-901 V2014_eMMC_By_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30769152 Size : 14.67 GB (15024.00 MB) --------------------------------------------------------------- CID Info CID : 1101003031364739320009CA30F0412B Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 0.0 Product serial number : (hex) 9CA30F0 Manufacturing date : 04/2014 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x06) 00000110 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x2 Part setting completed: 0x1 GP partition 1 size : 8 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab000000 bytes Device sector size : 512 bytes Partition offset : 3039272 Number of sectors : 2097152 Device Manufacturer :Condor_Electronics Device Platform :clovertrail Build ID :JDQ39 Display Build ID :redhookbay-userdebug 4.2.2 JDQ39 eng.svnadmin.20140808.121231 test-keys Release ID :4.2.2 Device Model :TRA-901G Device Name :TRA-901G Architecture ABI :x86 Architecture ABI2 :armeabi-v7a Build Description :redhookbay-userdebug 4.2.2 JDQ39 eng.svnadmin.20140808.121231 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G92_15_09_2019_07_43_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: reserved (00000028, 00052000) 164 MB P02: panic (00052028, 00004000) 8 MB P03: factory (00056028, 00010000) 32 MB P04: misc (00066028, 00040000) 128 MB P05: config (000A6028, 00040000) 128 MB P06: cache (000E6028, 00180000) 768 MB P07: logs (00266028, 00080000) 256 MB P08: system (002E6028, 00200000) 1024 MB P09: data (004E6028, 0186DFD8) 12.21 GB LOG REPAIRING : Code: Repairing from file "E:/SRF STARKRIMES/CONDOR/CONDOR_TRA-901_EMMC_SRF/CONDOR_TRA-901_VERSION 2014_eMMC_SRF/VERSION 2014/Condor_TRA-901 V2014_eMMC_By_STARKRIMES.srf". Write data verification is enabled. Writing GPT partition... Done. Writing reserved partition... Done. Writing panic partition... Done. Writing factory partition... Done. Writing misc partition... Done. Writing config partition... Done. Writing cache partition... Done. Writing logs partition... Done. Writing system partition... Done. Smart Repair is successfully complete. SW: 1.7.7; FW: 1.24. Disconnected. |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
