Member: 2749393
Thanks Meter: 39 | j320r4 dead [Solved] Hello,
I need to repair boot for j320r4, I used j320vpp pinout and it connected then flash firmware but still dead, Quote:
Welcome to Octoplus Pro JTAG Software version 1.7.7.
Started.
Reader #0: Broadcom Corp Contacted SmartCard 0
Reader #1: Generic EMV Smartcard Reader 0
Reader #2: Generic EMV Smartcard Reader 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J320VPP
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-J320VPP_EMMC.SRF
Voltage : 2.6V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J320VPP
Voltage : 2.6V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC Q316AB
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 150100513331364142007850D3FE33D1
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : Q316AB
Product revision : 0.0
Product serial number : (hex) 7850D3FE
Manufacturing date : 03/2016
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7692288 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 393216
Number of sectors : 5734400
Device Manufacturer :samsung
Device Platform :msm8916
Build ID :MMB29M
Display Build ID :MMB29M.J320R4TYS2ARA2
Release ID :6.0.1
Device Model :SM-J320R4
Device Name :j3lteusc
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :j3lteusc-user 6.0.1 MMB29M J320R4TYS2ARA2 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316AB_15_06_2019_19_05_40.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: apnhlos (00002000, 00007800) 15 MB
P02: modem (00009800, 0001CB80) 57.44 MB
P03: sbl1 (00026380, 00000400) 512 KB
P04: ddr (00026780, 00000040) 32 KB
P05: aboot (000267C0, 00001000) 2048 KB
P06: rpm (000277C0, 00000400) 512 KB
P07: qsee (00027BC0, 00000600) 768 KB
P08: qhee (000281C0, 00000400) 512 KB
P09: fsg (000285C0, 00001800) 3072 KB
P10: sec (00029DC0, 00000020) 16 KB
P11: pad (00029DE0, 00005220) 10.27 MB
P12: param (0002F000, 00005000) 10 MB
P13: efs (00034000, 00007000) 14 MB
P14: modemst1 (0003B000, 00001800) 3072 KB
P15: modemst2 (0003C800, 00001800) 3072 KB
P16: boot (0003E000, 00006800) 13 MB
P17: recovery (00044800, 00007800) 15 MB
P18: fota (0004C000, 00006002) 12 MB
P19: backup (00052002, 000037EE) 6.991 MB
P20: fsc (000557F0, 00001800) 3072 KB
P21: ssd (00056FF0, 00000010) 8 KB
P22: persist (00057000, 00004000) 8 MB
P23: persistent (0005B000, 00000800) 1024 KB
P24: persdata (0005B800, 00004800) 9 MB
P25: system (00060000, 00578000) 2800 MB
P26: cache (005D8000, 00096000) 300 MB
P27: carrier (0066E000, 00016800) 45 MB
P28: userdata (00684800, 016D57D8) 11.42 GB
Partition table has been found on device.
Backuping FRP data...
Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/FRP_0x5b000_0x800_15_06_2019_19_06_26.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
Removing FRP. Please wait... Done.
Don't forget to reconnect the device after writing to see changes.
Writting partitions. Please wait...
Writing partition modem from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/modem.bin file... Done.
Writing partition sbl1 from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/sbl1.mbn file... Done.
Writing partition aboot from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/aboot.mbn file... Done.
Writing partition rpm from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/rpm.mbn file... Done.
Writing partition boot from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/boot.img file... Done.
Writing partition recovery from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/recovery.img file... Done.
Writing partition system from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/system.img.ext4 file... Done.
Writing partition cache from J320R4TYS2AQI1_J320R4USC2AQI1_J320R4TYS2AQI1_HOME/cache.img.ext4 file... Done.
Writing is finished.
Reconnect the device to see changesDisconnected.
Disconnected.
| Please help |
