04-09-2019, 12:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | LG D295F repaired done via eMMC We back with you to the old beautiful time repairing LG D295F after got eMMC ERASED (BOOT 1-2) With the greatest OCTOPLUS LOG eMMC IN FIRST CONNECTION Code: Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D295 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_D295_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447316404050DA2F5D0127F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.5 Product serial number : (hex) DA2F5D0 Manufacturing date : 01/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G1d_09_04_2019_10_35_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. LOG WRITING BOOT 1-2 & FULL DUMP Code: Switched to boot area partition 1. Opening E:/FLASH TELEPHONE/LG/D/D295/BOOT1_Hynix eMMC.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.7.6; FW: 1.24. Switched to boot area partition 2. Opening E:/FLASH TELEPHONE/LG/D/D295/BOOT2_Hynix eMMC.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.7.6; FW: 1.24. Partition table has been found on device. Partition table is found from file E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin. Don't forget to reconnect the device after writing to see changes. Switched to user area. Writting partitions. Please wait... Writing partition GPT from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition modem from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition sbl1 from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition rpm from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition tz from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition sdi from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition aboot from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition rpmb from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition tzb from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition abootb from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition pad from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition modemst1 from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition modemst2 from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition misc from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition persist from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition laf from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition boot from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition recovery from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition fsg from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition fsc from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition ssd from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition DDR from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition encrypt from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition rct from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition drm from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition sns from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition factory from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition fota from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition sbl1b from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition mpt from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition cust from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition eksst from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition system from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition cache from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition userdata from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing partition grow from E:/FLASH TELEPHONE/LG/D/D295/FULL_DUMP_295F_eMMC .bin file... Done. Writing is finished. SW: 1.7.6; FW: 1.24. Reconnect the device to see changes p, li { white-space: pre-wrap; } LOG WRITING A FRESH FLASH (KDZ FIRMWARE) Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D295 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_D295_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447316404050DA2F5D0127F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.5 Product serial number : (hex) DA2F5D0 Manufacturing date : 01/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x20) 00100000 Boot partition enable : (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 770048 Number of sectors : 3070976 Device Manufacturer :lge Device Platform :msm8610 Build ID :KOT49I.A1460353724 Display Build ID :KOT49I.A1460353724 Release ID :4.4.2 Device Model :LG-D295 Device Name :l70pds_global_com Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :l70pds_global_com-user 4.4.2 KOT49I.A1460353724 1460353724 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G1d_09_04_2019_11_58_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: modem (00002000, 00020000) 64 MB P02: sbl1 (00022000, 00000800) 1024 KB P03: rpm (00022800, 00000400) 512 KB P04: tz (00022C00, 00000400) 512 KB P05: sdi (00023000, 00000400) 512 KB P06: aboot (00023400, 00001000) 2048 KB P07: rpmb (00024400, 00000400) 512 KB P08: tzb (00024800, 00000400) 512 KB P09: abootb (00024C00, 00001000) 2048 KB P10: pad (00025C00, 00001000) 2048 KB P11: modemst1 (00026C00, 00001800) 3072 KB P12: modemst2 (00028400, 00001800) 3072 KB P13: misc (00029C00, 00008000) 16 MB P14: persist (00032000, 00010000) 32 MB P15: laf (00042000, 0000B000) 22 MB P16: boot (0004E000, 0000B000) 22 MB P17: recovery (00059000, 0000B000) 22 MB P18: fsg (00064000, 00001800) 3072 KB P19: fsc (00066000, 00000400) 512 KB P20: ssd (00066400, 00000400) 512 KB P21: DDR (00068000, 00000400) 512 KB P22: encrypt (0006A000, 00000400) 512 KB P23: rct (0006A400, 00000400) 512 KB P24: drm (0006C000, 00004000) 8 MB P25: sns (00070000, 00004000) 8 MB P26: factory (00074000, 0000A000) 20 MB P27: fota (0007E000, 00010000) 32 MB P28: sbl1b (0008E000, 00000800) 1024 KB P29: mpt (0008E800, 00010000) 32 MB P30: cust (000A0000, 00019000) 50 MB P31: eksst (000BA000, 00000400) 512 KB P32: system (000BC000, 002EDC00) 1500 MB P33: cache (003A9C00, 0007D000) 250 MB P34: userdata (00426C00, 00310000) 1568 MB P35: grow (00738000, 0000FFDF) 31.98 MBSW: 1.7.6; FW: 1.24. Opening E:/FLASH TELEPHONE/LG/D/D295/D29510e_00.kdz file... Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition aboot... Done. Writing partition rpmb... Done. Writing partition tzb... Done. Writing partition abootb... Done. Writing partition persist... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition factory... Done. Writing partition sbl1b... Done. Writing partition cust... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.7.6; FW: 1.24. |
The Following User Says Thank You to starkrimes For This Useful Post: |
