04-12-2016, 14:58 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: algeria Age: 35
Member: 2266626 Status: Offline Thanks Meter: 40 | lg d722 repair boot done by usb done octoplus jtag pro Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic USB Smart Card Reader 0 USB interface selected. Connecting... CPU name : Qualcomm MSM8226 Flash Id : 117201 Page size : 512 b Block size : 512 b Block count : 15269888 Size : 7.28 GB Device : Unknown eMMC Connect successful. Please select file. Writting GPT partition... Done. Writting sbl1 partition... Done. Writting rpm partition... Done. Writting tz partition... Done. Writting sdi partition... Done. Writting aboot partition... Done. Writting pad partition... Done. Writting misc partition... Done. Writting laf partition... Done. Writting boot partition... Done. Smart Repair is successfully complete. Disconnected Last edited by Octopus box; 04-12-2016 at 15:09. |
The Following 2 Users Say Thank You to ibrahimtr For This Useful Post: |
01-19-2017, 10:27 | #3 (permalink) |
Crazy Poster Join Date: Dec 2009 Location: perlas ng silangan
Member: 1189220 Status: Offline Thanks Meter: 22 | hi.can you pls share me how did you repair your d722.. i buy medusa pro today and it also my 1st time to use this tool.. tnx in advance is this the procedure did you use? LG D724 repair via usb by Medusa Last edited by micoyo; 01-19-2017 at 10:36. |
01-19-2017, 11:00 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Currently supported repairing D722AR, not D722. You can try to make Smart Repair your D722 as D722AR. Also, You can try to connect your D722 as D722AR and then make Factory Repair, using original LG firmwares for D722. Repair D722AR is supported via USB. To connect and repair your phone You need to connect Test Point (TP) and USB cable. To repair your phone, do the following: 1. Install and run the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download "LG_D722AR.SRF" file via "Download *.srf" button in Software. 4. Select LG D722AR in Software list (device model will appear in Software list after You download SRF). 5. Press "Help" or "Pinout" button in Software to look at TP picture. 6. Connect the phone to PC via USB cable and put it into "Qualcomm...9008..." Mode using TP. Connect TP to GND - "Qualcomm...9008..." device should appear in PC Device Manager. If necessary, install "QHSUSB" driver from Medusa Pro Software installation folder. If your phone goes into "Qualcomm..." Mode automatically, no need to connect TP. 7. Disconnect TP. 8. Press "Connect" button in Software and wait while phone will be connected. 9. When phone will be connected successfully, press "SmartRepair" button and follow Smart Repair Wizard steps to repair the device. Please also look here different video manuals: https://www.youtube.com/watch?v=rNLN5Pv9W_w, https://www.youtube.com/channel/UCiy...ytLg9-1zt3zrrA, https://www.youtube.com/user/BoxMedusa. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-19-2017, 11:14 | #5 (permalink) | |
Member: 1189220 Status: Offline Thanks Meter: 22 | thanks for your quick response..i already connected the unit via TP.. i will try your suggestion sir and post result..thanks again Quote:
01-19-2017, 11:25 | #6 (permalink) |
Member: 1189220 Status: Offline Thanks Meter: 22 | which Partition do i need to Check for LG Factory Repair ? do i need to check it all? edited..i saw a video tuitorial..my mistake Factory Repair Via Usb Last edited by micoyo; 01-19-2017 at 11:35. |
01-19-2017, 11:39 | #7 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
01-19-2017, 13:23 | #8 (permalink) | |
Member: 1189220 Status: Offline Thanks Meter: 22 | thank you Sir Medusa Box..my Lg G3 is successfully repair via Factory Repair.. Quote:
03-07-2017, 20:32 | #10 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 43
Member: 168385 Status: Offline Thanks Meter: 21 | D722 repaired but now is error while phone starting Hi i repaired D722 as D722AR, after repair I wrote D722 firmware Phone is back to life but shows error customization: Current version is not avaiable for user...mcc/mnc 33403 Phone firmware is D722AR. I now its simply to write D722AR but must write firmware from Mexico network without european languages Maybe exist another way to cancel this error Help me Medusa supporter please |
03-10-2017, 10:16 | #12 (permalink) |
Member: 168385 Status: Offline Thanks Meter: 21 | I found solutions I wrote firmware 4.4.2 and error disapired, List of languages is from America, but when i put polish simcard, phone have polish language |
The Following User Says Thank You to sim-tel For This Useful Post: |
06-20-2017, 09:36 | #14 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please make the photo of phone's PCB in high quality, upload it somewhere and post here link, we will look whether we can help You with TP for your device revision. Also note, if your device goes into "Qualcomm...9008" Mode automatically, You no need to use TP. |
06-20-2017, 11:50 | #15 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 335721 Status: Offline Thanks Meter: 12 | Quote:
device usb plug not qualcom mode Tapatalk kullanarak iPhone aracılığıyla gönderildi | |
