01-04-2018, 10:56 | #1 (permalink) |
Major Poster Join Date: May 2016 Location: Tamil Nadu,Trichy
Member: 2568424 Status: Offline Thanks Meter: 11 | Lg-h818n usb repair not connect [Solved] mobile detect in pc qualcomm 9008 port but am using MSM8992 LOADER BUT ERROR WILL SHOW HERE IS EROR LOG Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. WHICH LOADER I CAN USE TO REPAIR PLS HELP Last edited by Octopus box; 01-05-2018 at 15:15. |
01-04-2018, 11:07 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
01-04-2018, 12:40 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | If You have Medusa Pro Box or Octoplus Pro Box, You can try do "Factory Repair" via eMMC. To connect and repair LG H818N via eMMC, do the following: 1. Download and install SRF "LG_H818P_EMMC_032G74.srf" for H818p via "Download *.srf" button in Software. 2. Select LG H818P in the Software list (model will appear in Software list after SFR installation). 3. Solder all necessary eMMC wires accordingly to the pinout picture ("Help" or "Pinout" button in Software). 4. Connect the device to box and press "Connect" button. 5. When device will be connected successfully, do "Factory Repair" (go to "Factory repair" tab in Software, select original LG firmware for H818N (use the latest available firmware version) and write it). 6. Post here the result. |
01-05-2018, 10:48 | #6 (permalink) |
Member: 2568424 Status: Offline Thanks Meter: 11 | Welcome to Medusa Pro Software version 1.5.1. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: FT SCR2000 3 Reader #4: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H818P SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H818P_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 11010030333247373400F5F628C1324B Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) F5F628C1 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 884736 Number of sectors : 8478720 Device Manufacturer : lge Device Platform : msm8992 Build ID : MRA58K Display Build ID : MRA58K Release ID : 6.0 Device Model : LG-H818 Device Name : p1_global_com Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : p1_global_com-user 6.0 MRA58K 1624911293df5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_05_01_2018_14_37_16.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 0002B000) 86 MB P02: pmic (00038000, 00000400) 512 KB P03: sbl1 (00038400, 00000800) 1024 KB P04: tz (00038C00, 00000800) 1024 KB P05: sdi (00039400, 00000400) 512 KB P06: hyp (00039800, 00000400) 512 KB P07: rpm (00039C00, 00000400) 512 KB P08: aboot (0003A000, 00001000) 2048 KB P09: sbl1bak (0003B000, 00000800) 1024 KB P10: pmicbak (0003B800, 00000400) 512 KB P11: tzbak (0003BC00, 00000800) 1024 KB P12: hypbak (0003C400, 00000400) 512 KB P13: rpmbak (0003C800, 00000400) 512 KB P14: abootbak (0003CC00, 00001000) 2048 KB P15: sdibak (0003DC00, 00000400) 512 KB P16: limits (0003E000, 00000400) 512 KB P17: devinfo (0003E400, 00000400) 512 KB P18: apdp (0003E800, 00000400) 512 KB P19: msadp (0003EC00, 00000400) 512 KB P20: dpo (0003F000, 00000400) 512 KB P21: spare1 (0003F400, 00000C00) 1536 KB P22: misc (00040000, 00008000) 16 MB P23: persist (00048000, 00010000) 32 MB P24: modemst1 (00058000, 00000C00) 1536 KB P25: modemst2 (00058C00, 00000C00) 1536 KB P26: fsg (00059800, 00000C00) 1536 KB P27: fsc (0005A400, 00000400) 512 KB P28: ssd (0005A800, 00000400) 512 KB P29: keystore (0005AC00, 00000400) 512 KB P30: DDR (0005B000, 00001000) 2048 KB P31: sec (0005C000, 00000400) 512 KB P32: encrypt (0005C400, 00000400) 512 KB P33: eksst (0005C800, 00000400) 512 KB P34: rct (0005CC00, 00000400) 512 KB P35: persistent (0005D000, 00001000) 2048 KB P36: spare2 (0005E000, 00002000) 4 MB P37: laf (00060000, 00018000) 48 MB P38: boot (00078000, 00014000) 40 MB P39: recovery (0008C000, 00014000) 40 MB P40: drm (000A0000, 00004000) 8 MB P41: sns (000A4000, 00004000) 8 MB P42: mpt (000A8000, 00010000) 32 MB P43: factory (000B8000, 00017000) 46 MB P44: fota (000CF000, 00005000) 10 MB P45: raw_resources (000D4000, 00002000) 4 MB P46: raw_resourcesbak (000D6000, 00002000) 4 MB P47: system (000D8000, 00816000) 4.043 GB P48: cust (008EE000, 00080000) 256 MB P49: cache (00970000, 00268000) 1232 MB P50: userdata (00BD8000, 02E60000) 23.19 GB P51: grow (03A38000, 00005FDF) 11.98 MB Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition pmic... Done. Erasing partition sbl1... Done. Erasing partition tz... Done. Erasing partition sdi... Done. Erasing partition hyp... Done. Erasing partition rpm... Done. Erasing partition aboot... Done. Erasing partition sbl1bak... Done. Erasing partition pmicbak... Done. Erasing partition tzbak... Done. Erasing partition hypbak... Done. Erasing partition rpmbak... Done. Erasing partition abootbak... Done. Erasing partition sdibak... Done. Erasing partition limits... Done. Erasing partition devinfo... Done. Erasing partition apdp... Done. Erasing partition msadp... Done. Erasing partition dpo... Done. Erasing partition spare1... Done. Erasing partition misc... Done. Erasing partition persist... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition fsg... Done. Erasing partition fsc... Done. Erasing partition ssd... Done. Erasing partition keystore... Done. Erasing partition DDR... Done. Erasing partition sec... Done. Erasing partition encrypt... Done. Erasing partition eksst... Done. Erasing partition rct... Done. Erasing partition persistent... Done. Erasing partition spare2... Done. Erasing partition laf... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition drm... Done. Erasing partition sns... Done. Erasing partition mpt... Done. Erasing partition factory... Done. Erasing partition fota... Done. Erasing partition raw_resources... Done. Erasing partition raw_resourcesbak... Done. Erasing partition system... Done. Erasing partition cust... Done. Erasing partition cache... Done. Erasing partition userdata... Done. Erasing partition grow... Done. Erasing is finished. SW: 1.5.1; FW: 1.22. Opening C:/Users/GSM HAKKIM/Desktop/H818N20a_00.kdz file... Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition tzbak... Done. Writing partition hypbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition factory... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition cust... Done. Writing partition cust... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.5.1; FW: 1.22. Disconnected. Now All is Done thanks For your help |
The Following 2 Users Say Thank You to planethakki For This Useful Post: |
