11-29-2017, 18:11 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: bulgaria Age: 45
Member: 560859 Status: Offline Sonork: 1594862 Thanks Meter: 17 | LG K430DSY Repair "dead" boot OK write boot 1 and 2 phones download mode ok DOX.bg - ???? ??????????? ?? ????? ????????? ? ?????????? ?? ??????? Last edited by Octopus box; 11-30-2017 at 06:32. |
The Following 3 Users Say Thank You to ramhard For This Useful Post: |
12-20-2017, 06:50 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. You can download SRF (Smart Repair File) or Boot1 and Boot2 from the Support Area (press "Download *.srf" button in Octoplus Pro Software). |
The Following User Says Thank You to Medusa Box For This Useful Post: |
08-02-2018, 08:35 | #4 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,041 | have tried to write boot 1 and boot 2 and even EXT from support and here is log Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : K430DS SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_K430DS_EMMC.srf Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D9E09D3EB54A3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 9E09D3EB Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x40) 01000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_01_08_2018_17_16_56.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.4; FW: 1.24. P00: FSBL (00000001, 00000028) 20 KB P01: QCSBL (00000029, 00000800) 1024 KB P02: OSBL (00000829, 00002000) 4 MB P03: APPSBL (00020000, 00002000) 4 MB P04: PART_2C (00022000, 00002000) 4 MB P05: PART_58 (00024000, 00002000) 4 MB P06: PART_77 (00026000, 0000C000) 24 MB P07: BOOT (00032000, 00006000) 12 MB P08: MODEM_ST1 (00038000, 00002000) 4 MB P09: MODEM_ST2 (0003A000, 00002000) 4 MB P10: AMSS (0003C000, 0000E000) 28 MB P11: PART_6C (0004A000, 0000E000) 28 MB P12: EXT2FS (00058000, 001D0000) 928 MB P13: EXT2FS (00228000, 00006000) 12 MB P14: EXT2FS (0022E000, 00140000) 640 MB P15: PART_60 (0036E000, 00006000) 12 MB P16: EXT2FS (00374000, 00004000) 8 MB P17: PART_6B (00378000, 00006000) 12 MB P18: EXT2FS (0037E000, 0038C000) 1816 MB P19: PART_FF (0070A000, 00002000) 4 MB P20: PART_FF (0070C000, 00002000) 4 MB P21: EXT2FS (0070E000, 00008000) 16 MB P22: PART_FF (00716000, 00002000) 4 MB P23: EXT2FS (00718000, 00010000) 32 MB P24: PART_FF (00728000, 00002000) 4 MB Switched to boot area partition 1. Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(BOOT1 LG K430DS) SAMSUNG EMMC Q316AB.BIN file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.6.4; FW: 1.24. Switched to boot area partition 2. Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(BOOT2 LG K430DS) SAMSUNG EMMC Q316AB.BIN file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.6.4; FW: 1.24. Writing EXT_CSD succesfully complete! Disconnected. thanks |
08-02-2018, 09:02 | #5 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | As I see from your Software log, there is Partition config set as "Device not boot enabled": Quote:
08-02-2018, 13:06 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Yes, You can do this via "eMMC service"->"Boot operation mode". |
08-02-2018, 13:13 | #8 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,041 | and after that log should be like Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit any emmc dump ??? can help with this ? |
08-02-2018, 13:22 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | We don't have dump. At first try to set correct Partition config value and try to put the device into Download (Emergency) Mode. If the device doesn't go into DM, try to do "Smart Repair". |
