03-22-2019, 05:50 | #1 (permalink) |
Junior Member Join Date: Dec 2007 Location: swabi pakistan
Member: 653038 Status: Offline Thanks Meter: 9 | LG ls775 dead boot repair solution plz [Answered] ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS775 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS775_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
03-22-2019, 09:15 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Hello. Quote:
1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. Also the problem can be with eMMC adapter, which You use. Please use Medusa Pro adapter. | |
