02-10-2017, 11:38 | #2 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Thanks Octopus Team we wait support more models Model Settings: Interface : eMMC Brand : LG Model : MS323 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_MS323_EMMC.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC K5XVMB Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501004B3558564D42067015C81C61AD Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : K5XVMB Product revision : 0.6 Product serial number : (hex)7015C81C Manufacturing date : 06/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/K5XVMB_10_02_2017_13_43_16.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.0; FW: 1.15. Erasing. Please wait... Done. SW: 1.3.0; FW: 1.15. Reapairing from file "C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_MS323_EMMC.srf". Write data verification is enabled. Switched to user area. Writting GPT partition... Done. Writting modem partition... Done. Writting sbl1 partition... Done. Writting rpm partition... Done. Writting tz partition... Done. Writting sdi partition... Done. Writting aboot partition... Done. Writting rpmb partition... Done. Writting tzb partition... Done. Writting abootb partition... Done. Writting pad partition... Done. Writting modemst1 partition... Done. Writting modemst2 partition... Done. Writting CustomPart partition... Done. Smart Repair is successfully complete. SW: 1.3.0; FW: 1.15. Disconnected. |
The Following User Says Thank You to juve2106 For This Useful Post: |
02-16-2017, 07:48 | #4 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
As You can see from the screenshot above, to repair this phone You need to use Octoplus Pro JTAG Software, not Octoplus JTAG Software. Also note, that repairing this device is supported via eMMC, so You need to have Medusa Pro Box, because Octoplus/Medusa Box HW doesn't support work with eMMC. Also, please look here: https://gsmserver.com/item/boxes-and...o-upgrade-kit/. | |
04-22-2017, 08:50 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Repairing this device is supported via eMMC (ISP), not via JTAG. eMMC pinout picture is inside of SRF (Smart Repair File). To look at pinout picture, do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF "LG_MS323_EMMC.srf " for MS323 via "Download *.srf" button in Software. 3. Select LG MS323 in Software list (model will appear in Software list after SFR installation). 4. Press "Pinout" button in Software. Also, please look here: http://forum.gsmhosting.com/vbb/f664.../#post12304074, http://forum.gsmhosting.com/vbb/f664.../#post12141188, http://forum.gsmhosting.com/vbb/f664.../#post11913343, http://forum.gsmhosting.com/vbb/f664.../#post11884711 |
