Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 09-22-2018, 16:22   #1 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
LG MS323 "dead" bot repair error [Answered]
Welcome to Octoplus Pro JTAG Software version 1.6.7. Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : MS323
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/lg_ms323_emmc.srf
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : 8 MHz
Connecting...
Device : Samsung eMMC K5XVMB
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
CID : 1501004B3558564D420645A6C66451B1
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : K5XVMB
Full name : KMK5X000VM-B314
Product revision : 0.6
Product serial number : (hex) 45A6C664
Manufacturing date : 05/2014
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 512 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1269760 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/K5XVMB_22_09_2018_16_19_12.bin.
Connect successful.
SW: 1.6.7; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: modem (00002000, 00020000) 64 MB
P02: sbl1 (00022000, 00000800) 1024 KB
P03: rpm (00022800, 00000400) 512 KB
P04: tz (00022C00, 00000400) 512 KB
P05: sdi (00023000, 00000400) 512 KB
P06: aboot (00023400, 00001000) 2048 KB
P07: rpmb (00024400, 00000400) 512 KB
P08: tzb (00024800, 00000400) 512 KB
P09: abootb (00024C00, 00001000) 2048 KB
P10: pad (00025C00, 00001000) 2048 KB
P11: modemst1 (00026C00, 00001800) 3072 KB
P12: modemst2 (00028400, 00001800) 3072 KB
P13: misc (00029C00, 00008000) 16 MB
P14: persist (00032000, 00010000) 32 MB
P15: laf (00042000, 0000B000) 22 MB
P16: boot (0004E000, 0000B000) 22 MB
P17: recovery (00059000, 0000B000) 22 MB
P18: fsg (00064000, 00001800) 3072 KB
P19: fsc (00066000, 00000400) 512 KB
P20: ssd (00066400, 00000400) 512 KB
P21: DDR (00068000, 00000400) 512 KB
P22: encrypt (0006A000, 00000400) 512 KB
P23: rct (0006A400, 00000400) 512 KB
P24: drm (0006C000, 00004000) 8 MB
P25: sns (00070000, 00004000) 8 MB
P26: factory (00074000, 0000A000) 20 MB
P27: fota (0007E000, 00010000) 32 MB
P28: sbl1b (0008E000, 00000800) 1024 KB
P29: (4748038E04E06, 80807EFEC71FB1FB) 6.658e+07 GB
Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/lg_ms323_emmc.srf".
Write data verification is enabled.
Writing GPT partition...
Write verification error 1. Possible reasons: damaged or write protected eMMC.
Disconnected.
Old 09-22-2018, 18:08   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,397
This error means, that there is a problem with eMMC and Software can't write data to it. You can try to disable "Write data verification" option and repeat "Smart Repair" operation. Most likely, this will not help, but You can try. If the problem is still remain, only the solution is a chip replacement.
The Following User Says Thank You to Medusa Box For This Useful Post:
Page generated in 0.15510 seconds with 8 queries
