03-28-2017, 09:18 | #1 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1663240 Status: Offline Sonork: 505020 Thanks Meter: 12 | Lg Volt 2 Ls751 HARD BRICK ( Qhsusb bulk _ Qualcomm-9008) How can I unbrick Lg Volt 2 Ls751 with "qhsusb_bulk" I have octoplus but I don't know how jtag work! Thanks advance |
The Following User Says Thank You to alshallal11 For This Useful Post: |
03-28-2017, 10:05 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. At first You need to connect the device via USB. If connection will be successful (if one of USB loaders in Software will be suitable), try to make Factory Repair using the latest original firmwares for this device. To connect the phone via USB, try to do the next: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Select "USB" option in Software. 3. Select "Brand: Custom Settings". 4. Select "Device (Core): Qualcomm MSM8916". 5. Select "Loader: QLoader_v1". 6. Connect the phone to PC. Install "Qualcomm" driver from the folder "c:\Program Files (x86)\Medusa Pro Software\Driver\QHSUSB\". As a result, "Qualcomm...9008" device should appears in PC Device Manager instead of "qhsusb_bulk" device. 7. Press "Connect" button in Software and wait while device will be connected (or not connected). 8. If device will be connected successfuly, do Factory Repair ("Factory repair" button in Software). Please note, that loaders can be not suitable (not compatible) for connecting the device. This depends on device CPU bootrom revision. Some devices (the same models) can be connected using loaders from Software and some аrе not connected, for example: http://forum.gsmhosting.com/vbb/f664...d-usb-2161902/, http://forum.gsmhosting.com/vbb/f798...table-2162110/. There are three general USB loaders for Qualcomm MSM8916 in Software. Try to connect the phone using each of them. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
03-28-2017, 15:33 | #3 (permalink) | |
Member: 1663240 Status: Offline Sonork: 505020 Thanks Meter: 12 | Quote:
will ls991 work with ls751?? | |
03-28-2017, 15:45 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | No, LS991 is based on MSM8992 CPU, but LS751 is based on MSM8916 CPU. To connect LS751 perform steps 1-9 and post the result. Try to connect the phone using "QLoader_v1", "QLoader_v2" and "QLoader_v1" USB loaders for MSM8916. |
03-28-2017, 16:10 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
03-28-2017, 16:26 | #7 (permalink) | |
03-28-2017, 17:52 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Unfortunately, we have no eMMC pinout for this device at the moment. Maybe someone has pinout picture for this phone and he will upload it here for You. |
